Author Topic: opinions and experience on a few tech questions - Drag Pipe, 40.5 Carb  (Read 7025 times)
Offline slayer_424
OK this is what I have is a 310 ESR stroker a 38a/s carb a trx5r ESR pipe with stock air box and snorkel. I'm gonna have the cylinder ported by K&T I'm also wondering about an out of frame drag pipe and possible 40.5 mm carb I need an air box eliminator intake was thinking of led. But I'm not sure what I will gain with this all done. I need info on how the pipes will compare I was told shearer. I'm looking for some help and possible parts. Thanks guys
Offline slayer_424
« Reply #1 on: February 18, 2014, 10:57:06 AM »
Also have v-force 3 reeds
Offline trx88
« Reply #2 on: February 18, 2014, 10:58:47 AM »
do you want to drag race only?
was your 310 ported already? is a 4mil 72mm setup too slow for you?
theres no replacement for displacement.
38 a/s is a good carb. but could be bigger
Offline slayer_424
« Reply #3 on: February 18, 2014, 11:11:22 AM »
That and messing around at home no trails I have two of them I like the 310 but I'm sick of getting my ass handed to me Im only 130 pound and getting traction is hard all shocks are soft as hell
The port job is only the trx9 from ESR its only a light scuff nothing special
Offline trx88
« Reply #4 on: February 18, 2014, 11:17:29 AM »
let some air out of your tires
Offline trx88
« Reply #5 on: February 18, 2014, 11:22:19 AM »
if your spinning out and thats the problem and your 310 is the cause why make it more torquey?
what are you drag racing that your loosing to
« Reply #6 on: February 18, 2014, 11:22:56 AM »
So you want a drag motor & setup?
I would look at a full blown drag port job first since you'd likely get more performance gains there.  Then explore an OOF (Shearer, CPI, FTZ) pipe.  And a carb set up on alcohol.
« Reply #7 on: February 18, 2014, 11:25:21 AM »
Sounds to me like you're trying to do too much with a 310...not really a drag set up. but thats just my .02. Not saying a 310 can't be a drag set up, because there are definitely some fast ones out there, just not a common one.
Offline slayer_424
« Reply #8 on: February 18, 2014, 11:28:22 AM »
I have tried sand tires race MX tires and tries with almost no air in them banshees that are hopped up and a couple R's 450r both Honda and yamaha I'm looking for as much as I can get out of the 310 hearing might be another cause have 13/39 probably should go with a 14 or 15
« Reply #9 on: February 18, 2014, 12:49:39 PM »
Change sprockets first, go 14, then 15. See if that helps(I'm sure it will). Or drop the rear.
« Reply #10 on: February 18, 2014, 01:02:58 PM »
I would send the cylinder off to Mat Shearer or Arlen at LED that can port the cylinder to their pipe,  K&T will do a good job also just be open to other builders.
The bad thing about a OOF pipe is it changes the look of the bike and people will expect it to be faster just because of the looks, so you better back it up or you will be teased even more when the banshees/450r beat you.
We have had real good luck with the FTZ inframe drag pipe, I am not saying its the best out there because we have not tested but the esr5 and 11 pipe against it but out of the 3 inframes the FTZ has worked the best. We did try a used FTZ out of frame that we hated but I think it was for a stock bore or was a early design and the header section of the pipe was much smaller than their inframe pipe and that is one of the most important sections of the pipe
Methanol would be a great power increaser, it does come with a down side, first your mileage will be cut in half compared to gas and you must purge the alcohol out of the carb and engine by running your normal gas premix at the end of everyday, but it will add almost 10% more power
« Reply #11 on: February 18, 2014, 01:05:04 PM »
Quote from: Rupp250;25957
excellant advice, more than likely you can run a 15 front and launch the bike in 2nd gear!
Offline slayer_424
« Reply #12 on: February 18, 2014, 01:25:48 PM »
OK I had a 14 front on it it seemed OK but seemed like it had a bit of bog in 5th but I was also just testing the bike and 3rd gear hole shot but that was too much it gave me even more tire spin . Does shearer Have an in frame ?  I was also told that the pipe has to go with the port job is that true ??
Offline trx88
« Reply #13 on: February 18, 2014, 02:14:47 PM »
are you using pump fuel?
Offline slayer_424
« Reply #14 on: February 18, 2014, 02:25:37 PM »
I normally use vp C12 or klotz 113 sometimes cam2 it depends on where I'm at
