Author Topic: The lost stealth shroud thread  (Read 85812 times)
Offline traxman
« Reply #60 on: May 11, 2014, 09:18:04 PM »
pm sent
Offline TRXforever
« Reply #61 on: May 11, 2014, 09:18:22 PM »
Is that red anodizing or powder?
« Reply #62 on: May 12, 2014, 08:06:02 AM »
I need a grille as well. I will get one as soon as you have them ready, Tony.
Offline Sky
« Reply #63 on: May 12, 2014, 09:42:28 AM »
Puma  a-shinin away!  Those look fantastic
« Reply #64 on: May 12, 2014, 10:52:00 AM »
Quote from: rablack21;33725
Hey Ryan, I will probably send you a new set of shrouds as I do not think those will fit the new apron. What problems did you encounter mounting those up? I think you said the a-arms hit. But these are 1/2" higher than the old ones so I do not think I can fix that.
« Reply #65 on: May 12, 2014, 10:57:55 AM »
Quote from: Pumashine;33737
Mounting them up was no problem. The one hole was about 3/4" off at the top, but you told me that before you sent them. They did hit the a-arms, so I grabbed the bottom front corner and pushed them up which bent everything slightly upward. I also took a hammer and bent the edge/corner up just a little til it cleared. Whatever you end up with, I'm sure I can make it work either way. :friendly_wink:
« Reply #66 on: May 12, 2014, 11:08:10 AM »
Quote from: TRXforever;33700
That was the anodized red color the run we made 15 years ago ended up being. There are just not enough of these made to get them anodized different colors. If I was making a 100 pieces it would be no problem.  It is more economical for you to send them to powder along with your other build parts. It was a $100 minimum for any color 15 years ago. Many parts were damaged in the process also. But back then there were 6 people working here. Now its just me.
Offline TRXforever
« Reply #67 on: May 12, 2014, 04:29:40 PM »
I would be fine with raw material. I have a great local powder coater! Let me know when these grille/apron sets are available, I am definately ALL IN on a set!
« Reply #68 on: May 31, 2014, 08:12:38 PM »
I pulled the shrouds off the 88 and put them on a bare frame to get a couple pics with a grill I made for Higgy 5 years ago
Oh yeah, and a top view so you can see that shrouds are fit to the top of the radiator also. There are not any other shrouds that do this.
« Reply #69 on: May 31, 2014, 10:30:30 PM »
Dam Tony you got skills!
Offline bnau267
« Reply #70 on: May 31, 2014, 10:35:06 PM »
Quote from: Hawaiiysr;35467
Second that.  Those are bad as$
Offline TRXforever
« Reply #71 on: June 01, 2014, 07:36:59 AM »
Grilles for sale yet? I am wanting one pretty bad!
Offline CeaserTheThird
« Reply #72 on: June 23, 2014, 12:05:20 PM »
Any updates Tony ?
Would love to own a set...
« Reply #73 on: July 05, 2014, 02:53:19 PM »
Quote from: CeaserTheThird;37314
Any updates Tony ?
Working on the grill and apron. The lip needs to be bent up a few more degrees. To get the correct angle of the apron a strip is placed flat along the plain you want to end up at and bend to meet where you want the flange to start. The white strip is the one I'm working with. The apron will get the same bend.
« Reply #74 on: July 05, 2014, 06:01:06 PM »
Quote from: TRXforever;35484
I am pretty close to the perfect fit. Just have to make a couple perf designs now.
