Author Topic: 86 R build white, red and black.. tons of photos..  (Read 22160 times)
Offline patman13mia
« Reply #30 on: March 03, 2014, 09:13:29 PM »
heres my esr 350cc that i have already sent to neil.. heard and read tons of great things about neils work and even better he answers all my questions.. just passing down knowledge!! cant wait to feel the difference in power compared to a stock cylinder.. never had a big bore before.. does anybody run a 350cc with a standard stroke?? also gona run a trx5 pipe and a 38 a/s carb with v-force 2 reeds.. i hope its a killer!! reliable killer that is
« Reply #31 on: March 03, 2014, 11:23:45 PM »
Thanks for all the pictures. We are picture *****s here. My dad is retired navy. I use to go on his ship all the time. Its was always fun seeing all the cool machinery hilos and aircraft.
I may be wrong but it looks like your lower motor mounts are welded on incorrectly. Its best to bolt your motor back in the frame when welding in your mounts. Using your motor as a jig insures that everything is lined up correctly.
« Reply #32 on: March 03, 2014, 11:29:27 PM »
Quote from: Hawaiiysr;27647
That depends if the cross rails are in the same position as stock. He did mention on the other site his motor sat a little to the right. Its best to fully mount the motor with head-stay and tack in the lower motor mounts. I can send him another set if needed.
Offline patman13mia
« Reply #33 on: March 04, 2014, 12:00:33 AM »
now i did put the motor in with all the bolts attached and also the rear motor mount.. i do feel that the engine is to far over to the left "when looking from above going fwd" ill post some pics so yall can see. and where you from in hawaii bro? oke of my best friends is from hawaii. hes from aliamano. i thank thats by pearl harbor area.. we go out there all the time and pull into port. great times!!
Offline patman13mia
« Reply #34 on: March 04, 2014, 12:04:47 AM »
here is the bike as is right now.. im at a stand still really waitin on bearings and seals and also neil has my engine and then ofcourse money.. or wife.. both are the same lol.. im prayin that the engine lines up correctly... fingers are crossed big time!! dont want to mess up the powder coat.
Offline patman13mia
« Reply #35 on: March 04, 2014, 12:07:55 AM »
couple more pics.. got a nice fluidyne rad with the shrouds to match.. great deal on those thank ya very much!!
« Reply #36 on: March 04, 2014, 12:09:20 AM »
I stand corrected. Upon looking at your pictures more. I thought the flat part of the lower mounts were pointing inward. The motor does not sit completely dead center. It does also help if you use the head stay as Tony mentioned. That way everything is lined up as it should.
Offline patman13mia
« Reply #37 on: March 04, 2014, 12:13:35 AM »
you think that could be an issue?? i bet for the pipe it is going to be.. FML!! and shit i dont even have a headstay.. never thought to get one..
« Reply #38 on: March 04, 2014, 12:21:41 AM »
As long as your front motor mounts bolt up you should be good. I once welded in the lower mount wrong and had to make custom front motor mounts. Sat about 1/4" to low. Pipes have alot of adjustment (give), you should have no problem with that.
Offline patman13mia
« Reply #39 on: March 04, 2014, 12:24:27 AM »
wheeeew you saved my life!! lol.. hey tony do you use a buffing wheel to shine your stuff? im thinking about shining up these shrouds and radiator.. also my handle bars a lil better and even my pipe.. any suggestions on what to use??
« Reply #40 on: March 04, 2014, 12:37:43 AM »
Quote from: patman13mia;27664
hey tony do you use a buffing wheel to shine your stuff? .. any suggestions on what to use??
Yes I have 2 buffing lathes. Most use mothers aluminum polish. If you put the polish on the handle bars wrap the rag around the bar in a complete circle and pull back and forth on each end of the rag. As the rag spins around the bar it makes polishing round surfaces much faster. This method works well on bumpers and pipes.
Offline patman13mia
« Reply #41 on: March 04, 2014, 12:41:13 AM »
your crazy dude!! how you comin up with this stuff?? lol.. ill see what i can do.. ill post some pics. tomorrow im goin in for the paint.. then start to get the parts prepped.. im excited!! im like a schoolboy again!! lol. just kiddin on that
« Reply #42 on: March 04, 2014, 12:46:21 AM »
Quote from: patman13mia;27666
Its stuff you learn in the parking lot at the dunes.:sign0108: The guy had a banshee with the usual 2 pipes. He polished up the mufflers to a mirror finish by hand in a short amount of time. I was like :sign0065: Oh, and that stands for "Way To Fast"
Offline patman13mia
« Reply #43 on: March 09, 2014, 12:20:54 AM »
im having a hard time finding some polyurethane paint locally so i may have to buy online from house of kolor.. here is the paint gun i bought from harbor frieght.. got the ol insurance on her so everytime it takes a dump on me ill be goin in for another one.. free!! bam
Offline patman13mia
« Reply #44 on: March 09, 2014, 07:22:33 PM »
hey tony here is some pics of the prep work i have done on some parts i want to paint.. cases will be red and i also have the side covers to strip but those will be black..
