Author Topic: slingshot clutch  (Read 9596 times)
Offline atvmxr
slingshot clutch
« Reply #15 on: March 07, 2014, 12:13:20 PM »
Quote from: Pumashine;28121
. I am guessing you just don't understand how the clutch operates!
well I thought I did, but seems I done went and learnt more info now    :onthego:
thanks OJ and Puma
slingshot clutch
« Reply #16 on: March 07, 2014, 02:23:45 PM »
Quote from: atvmxr;28122
thanks OJ and Puma
Its taken a few years of learning. When you go to replace a clutch the fibers on the outside are completely gone. The ones in the middle are still have lots a life one them. So if you get in a pinch you can always grab an old disk out of the middle and use it.
slingshot clutch
« Reply #17 on: March 07, 2014, 03:53:20 PM »
it uses the centripical force, the greater the rpms, the more centriphical force there is. the bearings you see sit on a angled "ramp" towards the outside of the clutch. as rpms increase, so does centripical force, therefore throwing the bearings out farther harder, therefore pushing in on the clutch plates harder, and allowing the clutch to hold more horsepower. i have ran one on my built raptor for several years. works well, and a cost effective alternative to the pricey direct drive units.
