Author Topic: ESR CR ignition kit tips  (Read 6122 times)
Offline 2strokesforever
« on: July 09, 2013, 12:54:49 PM »
Thinking of buying the complete CR ignition mod from ESR racing at the end of next week. Just wondering if you guys that have already made this mod could give me any hints on what to expect when installing it. Or any tips on what i need to do to get it installed right. Didnt know if it was a direct bolt on or if there was some things I might need to know before getting started. THX
88 TRX250R
295cc L.A. Sleeve Big Bore Kit
Pro Circuit pipes, Pro Design head
Ohlins-Works Performance Suspension
IMS Pro Series controls
38mm Keihin Air Stryker Carb
200 watt Ricky Stator stator
Boyesen Rad Valve
KEEP THE DINOSAURS ALIVE!!
Offline MajorCR3
« Reply #1 on: July 09, 2013, 01:05:48 PM »
Quote from: 2strokesforever;2149
Have you called and talked to them recently?  I went to order one about 3 weeks ago and I was told that the OEM cr250 cdi is discontinued by honda so they didnt have any complete kits.  And that I would have to find a used cdi to use on their setup.  Not a huge issue but could be a pain in the butt to find a good one.
Nick
2005 TRX363 Sphynx Hybrid..... :D
Luck is the combination of preparation and opportunity.
« Reply #2 on: July 09, 2013, 01:07:04 PM »
damn no i have not
88 TRX250R
Boyesen Rad Valve
« Reply #3 on: July 09, 2013, 01:10:00 PM »
Super simple hook up! I would get a coil mount from puma, a ground strap from a local parts house and have at it
« Reply #4 on: July 09, 2013, 01:27:05 PM »
yup now that i look at it those cdi's are no longer made...wtf
88 TRX250R
Boyesen Rad Valve
« Reply #5 on: July 09, 2013, 01:31:06 PM »
Called ESR and they said they was working on a new kit to put the new CR ign's on R's. Said to call back in a couple of weeks that they think they have it figured out.
88 TRX250R
Boyesen Rad Valve
« Reply #6 on: July 09, 2013, 04:11:56 PM »
Have you looked at the service honda cr500 set up? I beleive thats what it is... I also believe it has a light output also.
« Reply #7 on: July 09, 2013, 04:19:04 PM »
i have not thx
88 TRX250R
Boyesen Rad Valve
« Reply #8 on: July 09, 2013, 04:21:43 PM »
saw no mention of it working on trx250r's though
88 TRX250R
Boyesen Rad Valve
Offline Turftamer
« Reply #9 on: July 10, 2013, 08:10:38 PM »
Has anyone had any luck with aftermarket CR CDIs?
