Author Topic: LoneStar says my arms arent Lonestar? Seller told me they where  (Read 15152 times)
« Reply #15 on: March 19, 2014, 08:23:54 AM »
Well my point is its possible the heim joints are not stock.
« Reply #16 on: March 19, 2014, 08:29:03 AM »
I realize what you are saying. I should have also mentioned that the bends in the a-arms and the general construction does not look like LSR. Are they standard travel or long travel? I have had both from LSR and neither of them look like those.
« Reply #17 on: March 19, 2014, 08:39:26 AM »
They are standard travel.
At this point they dont look like any other A-arm i have seen.  Im at a loss as to who actually made them.
« Reply #18 on: March 19, 2014, 10:17:22 AM »
« Reply #19 on: March 19, 2014, 10:50:56 AM »
They sure look like LSR to me, set on my daughters look just like them, except hers has himes on the inside upper arm.
Those heims worn out ?.
« Reply #20 on: March 19, 2014, 11:06:59 AM »
On the right side the top is stiff, and the bottom is loose.
« Reply #22 on: March 19, 2014, 11:53:48 AM »
I wonder if they are denton a-arms.
« Reply #23 on: March 19, 2014, 12:13:47 PM »
If you go to this image of the closed ebay auction and zoom in they look just like these as far as i can tell.  I even have the copper/brass inserts where the a-arms mount to the frame.
http://www.ebay.com/itm/Honda-250R-Denton-Racing-A-Arms-Tie-Rods-Spindles-TRX250R-TRX-Control-/131022116946?nma=true&si=6mC3BrARe2DJodK1Ou8YRooVF3s%253D&orig_cvip=true&rt=nc&_trksid=p2047675.l2557
Offline atvmxr
« Reply #24 on: March 19, 2014, 12:25:58 PM »
they look like laeger/burgard arms to me.  I thought lsr usually had some webbing on the bottom a-arm.  the previous owner must have wanted to convert from the style of ball joints originally used to the heims and thus welded the jam nuts on to mount the heims too.
my pesos  :stung:
« Reply #25 on: March 19, 2014, 12:28:23 PM »
Na the arms are threaded on the inside as well.  I had to grind one of the jamb nuts and break the weld so i could back it off and adjust camber.  man i hope that they arent whats holding it.
Offline Flyin_250r
« Reply #26 on: March 19, 2014, 01:04:00 PM »
That top a arm sure makes it look like lsr to me
Offline chadj1980
« Reply #27 on: March 19, 2014, 01:40:46 PM »
the denton arms the balljoints go all the way through the bottom arm with a nut on the end... From the pics doesnt look like yours do...
« Reply #28 on: March 19, 2014, 02:06:59 PM »
And the bottom arms are completely straight, no bend.  I was sure they where LSR.  Maybe they are just upgraded with Heims.  I bought a pair of heims, so we will see if they fit.
Offline chadj1980
« Reply #29 on: March 19, 2014, 02:18:51 PM »
they look just like mine minus the heims.. I know for a fact mine are lsr...
