Author Topic: Pilot top end  (Read 9328 times)
Offline troybilt
Pilot top end
« on: March 19, 2014, 10:30:36 AM »
Does a 250r reed cage fit the pilot top end?  I'm wanting to get rid of the 32mm Round slide carb in my dad's pilot and go to a 35-38 A/S.  I don't know much about the pilot top ends yet.
Elsinore 496cc Saber
Pilot top end
« Reply #1 on: March 19, 2014, 10:44:50 AM »
A member over on Mac Dizzy. Com deals with those, "hoser" & can provide you with anything you need to know. Has been for many years, so he has some info.
Pilot top end
« Reply #2 on: March 19, 2014, 11:01:02 AM »
The intake manifold is the same bolt pattern. But the pilot intake goes straight out and the trx makes a turn. I have a 38mm AS to put on mine but the stock manifold is too constrictive. Let me know if you find one that comes straight out like the pilot. Otherwise you have to reroute the intake system.
Pilot top end
« Reply #3 on: March 19, 2014, 11:28:46 AM »
Didn't someone try the quadzilla or cr500 intake at one point in time on the pilot?
Offline troybilt
Pilot top end
« Reply #4 on: March 19, 2014, 11:58:41 AM »
I wonder if the CR intake boot will work on the rad valve its straight as well I think.  Thanks for the info
Offline atvmxr
Pilot top end
« Reply #5 on: March 19, 2014, 12:27:53 PM »
Quote from: troybilt;29380
pretty much what I was going to say
Pilot top end
« Reply #6 on: March 19, 2014, 12:52:27 PM »
I tried putting on the rad valve but it points the carb to the left. Hooks up great with the bigger boot. Just does not follow the stock path. Does look odd and the carb does not sit plumb
Offline troybilt
Pilot top end
« Reply #7 on: March 19, 2014, 01:32:25 PM »
Well the reason I asked, is I just picked up a pilot, complete, and looking to mod it a little...  I can't leave anything alone...  LOL
Pilot top end
« Reply #8 on: March 19, 2014, 02:39:51 PM »
Been trying to put mine back together for 10 years. :lol: I think the solution was to go with a v-force reed cage and make your own intake or something that looks like this which seems to look straight. http://www.ebay.com/itm/Moto-Tassinari-Delta-3-Reed-Valve-System-V305B-Honda-Four-Trax-86-89-V-790861-/390794039417?pt=Motorcycles_Parts_Accessories&hash=item5afd23d079&vxp=mtr
Offline mennis1971
Pilot top end
« Reply #9 on: March 19, 2014, 04:58:12 PM »
Sounds like it's time for Troy to make something new and cool! I always enjoy seeing your work Troy.
Pilot top end
« Reply #10 on: March 19, 2014, 06:18:20 PM »
The rad valve may be easier to modify because it's metal. Do the karting guys use a straight intake?
Offline troybilt
Pilot top end
« Reply #11 on: March 19, 2014, 09:08:03 PM »
What do you want for the 35 Benjamin?
Pilot top end
« Reply #12 on: March 19, 2014, 09:31:54 PM »
There is a guy on FB I am cutting some blank intake manifold plates of 3/8" aluminum. If you want one Troy I can cut it for you and you could weld a tube to it. The modifying the rad valve is a good idea too Dan.
Offline troybilt
Pilot top end
« Reply #13 on: March 19, 2014, 09:42:22 PM »
What size hole is in the center on the one you're cutting?  I could fab one up forsure.  I think we're onto something here.  Dan hold onto that 35a/s...  LOL!
Pilot top end
« Reply #14 on: March 19, 2014, 09:57:16 PM »
Quote from: troybilt;29429
He wants them blank in the middle. If you know what size you want it will just cut that.
