Author Topic: Pilot top end  (Read 9430 times)
Offline troybilt
Pilot top end
« Reply #15 on: March 19, 2014, 09:58:36 PM »
I'll measure my rad valve and see, I have no idea, 40-45-ish mm if I remember right.
Elsinore 496cc Saber
Pilot top end
« Reply #16 on: March 19, 2014, 10:17:53 PM »
I am looking at the pilot intake boot. It is offset the right 1/2" and angles down. Looks like the hole needs to go through at an angle. Oh well, I guess thats what weld is for.
Offline JTRtrx250r
Pilot top end
« Reply #17 on: March 20, 2014, 12:18:11 AM »
forget who did it , but ran against a guy that had a cr500 topend in his, fast as %$#^ !
- Jeremy -
Pilot top end
« Reply #18 on: March 20, 2014, 04:16:46 AM »
3-D print the intake tube you want.
Offline mennis1971
Pilot top end
« Reply #19 on: March 20, 2014, 07:08:10 AM »
Don't worry, it will still look stock. Haha!
LOL sounds like something I suspected a few years ago on one of Troy's different rides! You know what I'm talking about Troy.
Offline Wes350x
Pilot top end
« Reply #20 on: March 20, 2014, 07:13:55 AM »
OOPS, just saw it was for a real pilot 400 lol.
« Last Edit: March 20, 2014, 08:57:48 PM by Wes350x »
1988 250R
Offline troybilt
Pilot top end
« Reply #21 on: March 20, 2014, 08:05:42 AM »
Quote from: mennis1971;29452
Hey, that 89 is bone stock!  LOL!!  Only a thinner head gasket that was it, not even a pipe at that time.  195 psi and it runs awesome for stock a stock bike.
Yea this system is for my Dad's 89 Honda Pilot, not a pilot cylinder in a 250r...  FYI.  Does anyone know why the carb has coolant lines running to a from the carb?  Seemed strange to me, but I haven't dug into into too much yet.
Pilot top end
« Reply #22 on: March 20, 2014, 09:42:21 AM »
never worked on a pilot but many models of snowmobiles would have coolant run thru the carbs to keep them freezing, I suspect honda expected these to run year round so that was a precaution.
I would put a small valve inline to shut the coolant off in the warm temps
Offline troybilt
Pilot top end
« Reply #23 on: March 20, 2014, 09:46:07 AM »
Quote from: rsss396;29459
Ah that's interesting, never been around snowmobiles.  But that makes sense.  So to hook up the 35 A/S, I can just bypass the carb altogether then.   I better do some research on this bad boy.
Pilot top end
« Reply #24 on: March 20, 2014, 11:16:43 AM »
Quote from: troybilt;29461
I figured it had something to do with the temps and choking the carb. Or just maybe to warm it up quick in freezing weather. Yep, you can just bypass the coolant lines to the carb- block them off or remove. It does not get cold here. :lol:
Offline mx250r91
Pilot top end
« Reply #25 on: March 20, 2014, 05:11:59 PM »
Quote from: danhung11;29420
You could take a Rad Valve and just hack of the end, then weld a straight tube off to it.
That's what I was just thinking I bet Jerry could weld something up and it would work perfectly!
