Author Topic: Laeger XC "ONE of ONE"  (Read 74619 times)
Offline bnau267
« Reply #45 on: May 18, 2014, 11:39:34 AM »
Mounted up the heel guards to get an idea of how the fenders mate up.  My engine builder is sending the cases/covers out for powder.  The million dollar question is 'will the headstay line up with the CP top end?'  If it doesn't, I'll be begging Laeger to make me a new custom headstay.
Offline DnB_Racing
« Reply #46 on: May 18, 2014, 03:39:45 PM »
my laeger protrax frame head stay (with stabilizer bracket ) fit like a glove to my 363 sphynx
just a tip.....clean ALL your mounting surfaces both motor and frame mating surfaces of all powder coating or you will be fighting the alignment on every bolt you install
Offline bnau267
« Reply #47 on: May 18, 2014, 03:56:01 PM »
Will keep in mind for sure.  As far as the head stay, I think [MENTION=483]Tbone07[/MENTION] had some issues with the Laeger headstay and sphynx lining up on his build so I figured I'd have the same problems.  Hopefully it will be all good.
Offline DnB_Racing
« Reply #48 on: May 18, 2014, 04:04:17 PM »
it took me a couple try's, My first try was installing that bolt last and was a fail.... I think the order that worked best for me, was bottom first then head stay, then rear then front..
it might take a couple trys but it should go.
either way good luck and be patient it will go without any Hammers or bending, I did use a piece of wood to persuade it a little and it went right into place
Offline ryanowarrior
« Reply #49 on: May 18, 2014, 09:49:05 PM »
What engine builder u using? Askin cause I'll need/want my cases powdered also
thanks
Laeger Crf
Laeger R
Walsh R
Walsh Crf (in the works)
Offline bnau267
« Reply #50 on: May 18, 2014, 11:33:08 PM »
Quote from: ryanowarrior;34320
thanks
Schorr MotorSports, Inc.  He does not do the PC work but the company he uses is top notch.  [MENTION=498]312R1[/MENTION] had his Laeger frame and some other stuff done by them...QC cover was a perfect match to Honda OEM I believe.
Offline 312R1
« Reply #51 on: May 18, 2014, 11:43:50 PM »
Quote from: bnau267;34323
Schorr MotorSports, Inc.  He does not do the PC work but the company he uses is top notch.  @312R1 had his Laeger frame and some other stuff done by them...QC cover was a perfect match to Honda OEM I believe.
Bob, is that Cody's business name. Lol if it is I never knew it.
« Reply #52 on: May 18, 2014, 11:56:58 PM »
Cool thanks man....plan on sendin my bottom end to LED but didn't know if they or have someone to repowder my cases
Laeger Crf
Laeger R
Walsh R
Offline bnau267
« Reply #53 on: May 19, 2014, 12:02:30 AM »
Quote from: 312R1;34324
Yeah that's the official business name.  You are cracking me up right now.  All about perspective though!  While you two are swapping parts being buddies I'm a paying customer....LOL.  I hope that PC guy does as nice a job on my engine as he did on your QC cover.
Offline 312R1
« Reply #54 on: May 19, 2014, 12:18:47 AM »
Quote from: bnau267;34326
Lmao. Yeah he will do a top notch job for you. I haven't seen anything yet to make me think otherwise. The good thing for you is that this is his slow time of the year. Not much sprint car chassis to do.
Offline bnau267
« Reply #55 on: June 15, 2014, 12:36:44 AM »
Nothing like doing 8 sets of swingarm bearings in one sitting.  Took a while but it got them all pulled from the pro-trax so I'm all set to have the tops chromed and the lowers powdered to match the frame.  My stem should be showing up next week.  Now the big decision is do I simply buy new bushings from Laeger or get new bearings and have new sleeves cut.  These felt like butter with the bearings installed.  Anyone know a good machine shop within driving distance from Pittsburgh?  Thinking I'll have them ground to within tolerance and then hard chrome plated.
Offline bnau267
« Reply #56 on: July 17, 2014, 10:04:36 PM »
Should have the LED 300PV ready to go in a few weeks.  Still need to send these out for powder.
Offline bnau267
« Reply #57 on: July 17, 2014, 10:08:42 PM »
Still not sure on lower arm color.  I may go with a stock Honda silver or possibly an old school Laeger Grey.
« Reply #58 on: July 18, 2014, 08:09:41 AM »
Looking nice! I like when the a-arms and swingarm are the same color. What swinger are you running on this?
Offline bnau267
« Reply #59 on: July 18, 2014, 10:22:39 PM »
Running a Laeger CR500.  Currently Chrome but planning to match the lower arms.
