Author Topic: Streamline Billetanium Hydraulic Clutch  (Read 4982 times)
Offline 2strokesforever
« on: July 09, 2013, 08:59:25 PM »
Anyone bought a Streamline Billetanium Hydraulic Clutch for a R yet? Wondering if they work as good as the Magura ones. Is easier/harder to bleed.
88 TRX250R
295cc L.A. Sleeve Big Bore Kit
Pro Circuit pipes, Pro Design head
Ohlins-Works Performance Suspension
IMS Pro Series controls
38mm Keihin Air Stryker Carb
200 watt Ricky Stator stator
Boyesen Rad Valve
KEEP THE DINOSAURS ALIVE!!
Offline Turftamer
« Reply #1 on: July 09, 2013, 11:08:18 PM »
I ran a streamline on my 86 for only two rides before I decided to tear the quad down for a rebuild.  I've never owned a Magura so I can't really compare.  Bleeding wasn't too difficult.  I used a cheap parts store hand vacuum pump on the slave cylinder with the included bottle to catch any fluid.  The slave cylinder dosen't seem to have a very long stroke, so I had to adjust the linkage all the way in.  Even with the short travel, I had no problems disengaging the clutch.  The only problem I had was that the master cylinder cap o-ring doesn't seem to seal completely.  After each ride, I had to wipe off a little dust that had collected around the cap.  That, and the only color I could get was anodized orange.
« Reply #2 on: July 10, 2013, 01:28:12 PM »
bump
88 TRX250R
Boyesen Rad Valve
Offline d-rock
« Reply #3 on: July 10, 2013, 01:34:25 PM »
i Have one. it works great but was a ***** to bleed.
Offline Vootie
« Reply #4 on: July 12, 2013, 11:13:03 PM »
Do these help clutch pull at all?  My clutch is brutal even with the 89 update and an ez pull lever...
Offline d-rock
« Reply #5 on: July 14, 2013, 12:12:06 AM »
It pulls smoother and a little easier ,but I wouldn't say it pulls a lot easier. my clutch was never hard to pull.
