Author Topic: Modify steering, NOT 250r-related...  (Read 6563 times)
Offline wilkin250r
« Reply #15 on: April 01, 2014, 07:40:06 PM »
I can't put on taller front tires, it's 4-wheel drive, I need all the tires to be the same size.
What I think I'll do is I'll modify one and test it and get it to where I want, then I'll make a complete new one.  I'll spend a couple hundred bucks getting somebody with a water jet or some other machine-shop to cut the flat steel exactly how I want.  Then I'll take an old piece and cut the splined section out, put it on a lathe and true it to the dimension I want, and weld it all together.
I got no problem spending $300 to fix this issue.
« Last Edit: April 01, 2014, 07:50:19 PM by wilkin250r »
« Reply #16 on: April 01, 2014, 08:31:55 PM »
right on,you asked for thoughts and I gave you mine .
Offline wilkin250r
« Reply #17 on: April 03, 2014, 01:33:24 AM »
Bugger.  Up until now I was throwing out possible scenarios and solutions because it was easier to get to this website than it was to get to the machine to test it, but all along I was hoping and expecting to find an easier solution.  I really thought I was going to get to the machine and find it had 3/4 inch of toe-out, which would easily explain the over-sensitive steering.
Nope,  I had just under a 1/2 inch of toe-in.  A quarter inch would probably better, but it's obviously NOT the cause of the over-sensitive steering.  It looks like I'm going to be exploring more exotic solutions.
And I double and triple-checked.  Aside from replacing the rear shock with something 2 inches shorter, I don't see any way to adjust the caster on this thing.
