Author Topic: piston failure chart  (Read 2945 times)
« on: July 09, 2013, 10:12:25 PM »
[ATTACH=CONFIG]267[/ATTACH]
« Last Edit: July 18, 2013, 09:59:24 AM by rsss396 »
« Reply #1 on: July 09, 2013, 10:56:58 PM »
well not really I can't get the picture large enough to read the small print :(
it is a PDF file that I converted but it killed the quality how do I attach PDF's
« Reply #2 on: July 09, 2013, 11:18:55 PM »
yes Dan the large image is photobucket and the small is attached, I can go as high as 400% on IE and its readable but not as nice as the PDF
Offline atvmxr
« Reply #3 on: July 10, 2013, 12:34:30 PM »
awesome!
that next to last one should read big end rod bearing let go (it does vaguely hint at a lower end problem) ....  I've had that bite me a couple times not realizing that was the issue only to destroy a new piston in a few minutes....
Offline trx250r88
« Reply #4 on: July 10, 2013, 10:44:35 PM »
Quote from: atvmxr;2505
awesome!
i had that happen last year too.the piston looked just like pic.rod bearing went,piston detnating on the edge.the motor still ran with major knocking noice.
