Author Topic: Rear caliper spacer??  (Read 7821 times)
Offline Higgy87trx425
« Reply #15 on: April 07, 2014, 12:41:04 PM »
Quote from: silverlake250r;31069
Yeah grind it down. Washers are not a good way to fix anything ever. It looks extremely trashy.
Yeah I agree!! Kinda of a hokey way to fix it. Not on my bike!!!
Thanks Higgy.
« Reply #16 on: April 07, 2014, 12:53:49 PM »
I don't think your Anti-fade is in all the way.....look at the pic....the shaft has a wear mark where the seal wore off the anodizing....looks like the amount needed to move to the left (swingarm side) What Bearings did you install ? Maybe they're wider ? :)
« Reply #17 on: April 07, 2014, 06:32:38 PM »
Quote from: Langbolt;31073
The anti-fade is brand new. That mark your talkin about is the steel sleave thats preesed onto the alum. I'm gonna take a look at the bearings today and make sure that they're pressed in all the way.
 Thanks Higgy
« Reply #18 on: April 07, 2014, 11:42:44 PM »
It appears that my bearings may not be pressed in all the way on the caliper side! I bought it this way used, Apparently I need to quit buying other peoples junk!!! So I'm torn, Do I try an pull the bearings to replace them or do I heat up the carrier and try and press that side in more or should I just buy a new Bearing carrier?
 Thanks Higgy
« Reply #19 on: April 08, 2014, 01:36:51 AM »
I don't think pressing one side is an option the spacer tube in the middle makes it wear you have to move both sides.the  tube may be to long
Offline TLR-Online
« Reply #20 on: April 08, 2014, 06:29:48 PM »
My RPM Antifade is .6050
« Reply #21 on: April 09, 2014, 01:04:25 AM »
So I inspected the bearings a little closer and as it turns out the brake side wasn't pressed I all the way. So I got pressed in the rest of the way and my rear brake now fits over the rotor, I win!! Thanks for all the help guys!!
 Thank Higgy
« Reply #22 on: April 09, 2014, 01:09:56 AM »
 Thanks Higgy
« Reply #23 on: April 09, 2014, 08:32:39 AM »
Quote from: Higgy87trx425;31207
 Thanks Higgy
Higgy, what'd you do to that fresh powder in the middle of the swinger?!?!?
« Reply #24 on: April 09, 2014, 11:15:56 AM »
Lol, I showed it who the BOSS was!!! I was waiting for that comment! Its actually not powder its just color matched regular paint.
Thanks Higgy
Sent from my XT1030 using Tapatalk
