Author Topic: crank gear and cb timing  (Read 4656 times)
Offline 2k1lvr
« on: April 06, 2014, 07:11:44 PM »
putting bottom end back together and my new +4 hot rods crank doesnt have a mark on the shaft to line up the gear. so i held crank at tdc and put the gear on with mark straight up then lined up outer mark with mark on counter balancer gear is this ok?????:grumpy:
89 trx5 pipe 38as carb esr330 pv cyl ported by BUBBA RAMSEY at BHP,+4 crank,cr ign,elka front shocks,lsr axle
« Reply #1 on: April 06, 2014, 07:21:07 PM »
Quote from: 2k1lvr;30991
Yep, just imagine there is a dot/mark at TDC of the crank and put the gear on.
Offline DnB_Racing
« Reply #2 on: April 06, 2014, 08:52:14 PM »
Quote from: Pumashine;30994
does it matter if it is +4 or are they all TDC
« Reply #3 on: April 06, 2014, 09:12:02 PM »
Quote from: DnB_Racing;31001
If you look close Honda puts the mark on the crank at TDC. I think common sense will take over now.
Offline DnB_Racing
« Reply #4 on: April 06, 2014, 09:17:25 PM »
Quote from: Pumashine;31004
lol there is nothing common about my sense..
ya that makes sense I just wasn't sure if it changed any angles at all (I've never held a stroke crank) to see were the pin actually goes
and I failed terribly at geometry
« Reply #5 on: April 06, 2014, 09:28:16 PM »
Quote from: DnB_Racing;31005
I was not referring g to you Barry. For some reason hot-rods started to leave the mark off. They probably figured it was TDC for OEM so its kinda like it never changed.
Offline DnB_Racing
« Reply #6 on: April 06, 2014, 09:37:17 PM »
its all good:loyal:
I was just curious about if the weights had been offset on a stroker I never really thought about that
always something to learn
« Reply #7 on: April 07, 2014, 12:37:18 AM »
Quote from: DnB_Racing;31009
I think you are referring to crank balancing. The cranks do not need to be balanced until the weight of the piston exceeds what your counterbalancer is set up for. The new +4 hotrods cranks are manufactured with the pin in a different location. It has not been moved as they have been re-manufactured in the past.
Offline 2k1lvr
« Reply #8 on: April 07, 2014, 08:50:16 PM »
Thanks everybody!!
