Author Topic: Wtb long travel a arms  (Read 3718 times)
Offline Hockey8381
« on: April 07, 2014, 02:12:58 PM »
Looking for long travel a arms in good shape already have shocks just need arms 2+1 or 3+1
Offline atvcrazy245!!
« Reply #1 on: April 19, 2014, 01:55:15 AM »
I have +2+1 walsh arms let me know if your interested call or text 410-924-2763
Offline D Bergstrom
« Reply #2 on: April 20, 2014, 02:13:53 AM »
I have a set of Teixeira Tech +2.5 a-arms. Lowers are powdered gloss black and uppers are chrome. (No time on the arms since powder and chrome.) If interested, let me know and I can send pics.
Doug
2004 TRX450R, 2008 TRX700XX
2008 TRX700XX
2005 TRX450R
1986 TRX250R
« Reply #3 on: April 20, 2014, 05:46:53 AM »
every long travel arm will require a different shock length. Teixeira Tech for example will require 21 5/8" shock. (gotta check my notes to be sure) other brands require 19" through 21". the shocks you have now may not be the correct length for the arms you buy. you should check your shock length then buy arms that require the same length shock.
just a heads up. id hate for you to spend all kinds of money only to find out your set parts don't work together.
« Reply #4 on: April 20, 2014, 09:26:44 PM »
yea the walsh's are 19''
Offline trx250scar
« Reply #5 on: April 20, 2014, 09:41:55 PM »
I have a set of JD Performance arms on my 450. Really nice arms. Easier to adjust. Custom colors available. Also He can make the arms for any shock length. Can get them in either standard or mgc( Max ground clearance ). Dave herron owns JD Performance. He built all the chassis at laeger for years. The Guy knows his stuff.
Offline trx250scar
« Reply #6 on: April 20, 2014, 09:54:45 PM »
After reading seems u may b looking for used. If you find some that r proper up and down travel great but it will b hard. JD can make What u need and they are reasonable.
Offline D Bergstrom
« Reply #7 on: April 22, 2014, 04:10:12 PM »
Quote from: Hawaiiysr;31907
Hawaiiysr is correct. I didn't notice you already have shocks, if that is the case, you have to match the extended and compressed lengths to the arms. Depending on what shocks you have, that could limit the arms you could use. As stated above, shock lengths can vary greatly between a-arm manufacture's. (Teixeira Tech arms use a 20" shock.) The lengths can even vary with the tire size you are running. Best bet is to get your shock specs, then see what arms will work.
Doug
2008 TRX700XX
2005 TRX450R
1986 TRX250R
