Author Topic: Duner project  (Read 12806 times)
Offline 1986trx250r181
Duner project
« on: April 11, 2014, 09:38:37 PM »
I have recently started my duner project and would like to share with you guys. I am using a 87 frame and for a motor I am going with a psi 425 using a yz490 rod with a kx500 piston should be around the 465cc mark. I will be using the psi carb for now, haven't herd good reviews for the carb but I got the motor running last fall and seemed to run great, so I am going to give it a try if it doesn't work out will be switching to something else. I am going to try running The led puma inframe exhaust. I am very exited about the build. Will be keeping it updated with pics!
Duner project
« Reply #1 on: April 11, 2014, 09:45:26 PM »
This is the bike last year. I just put the motor in place to see how it ran. so this is what I started with.
Duner project
« Reply #2 on: April 11, 2014, 09:53:52 PM »
I got the frame powder coated with a few other things. I will be using the JJ&A racing axle with a +8 swing arm and +1 drag/dune a arms. And a picture of the engine.
Offline GO OVRIT
Duner project
« Reply #3 on: April 11, 2014, 10:07:54 PM »
Nice.   I like the white frame.
Offline patman13mia
Duner project
« Reply #4 on: April 12, 2014, 01:10:29 PM »
Same color scheme as my build. Which might i add is badass colors. That engine looks pretty cool also. Put lots of pics up of your work so we can see what its lookin like man
Duner project
« Reply #5 on: April 12, 2014, 09:07:52 PM »
I think I will be going with 88 plastics. I have fronts in really good shape but the backs have a piece broke out of them. I was going to order some maier back plastic but im not sure how the colors will match up.
Duner project
« Reply #6 on: April 12, 2014, 09:11:19 PM »
made a little progress today put the a arms and spindles, steering stem and Rad.
Offline ACampbell
Duner project
« Reply #7 on: April 17, 2014, 12:50:31 AM »
Looks good.  Keep us updated.
Duner project
« Reply #8 on: April 17, 2014, 08:00:24 AM »
Looks like a fun build!  Which dunes do you ride at?
Offline Sky
Duner project
« Reply #9 on: April 17, 2014, 08:34:25 AM »
Im liken the white frame. Makes the lines pop when bright and shiny. Keep up the great build.
Offline jamieg45
Duner project
« Reply #10 on: April 17, 2014, 10:24:07 AM »
Looking good man, I would love to try a psi motor out myself. When I had sleds they all had psi, pioes, clutch kits and some other mods as well. I've always wanted one of there motors.
01 Lsr 250r
00 Walsh 250r
Duner project
« Reply #11 on: April 18, 2014, 09:34:23 AM »
I am from Alberta, there are some smaller dunes close by but usually do a few trips down to Idaho or Oregon in a year. I have never ridden a psi built motor before I have read that they have some over heating issues and also some problems with the dial-a-dome head. On this certain motor the head is fixed so there is no adjustment. hopefully that will get rid of that issue. And I will be running a gauge so I will keep close watch on the temp.
Duner project
« Reply #12 on: April 18, 2014, 09:53:01 AM »
made some good progress over the week. got the front brakes and shocks on. put the motor in place and mounted up the new led pipe!
Duner project
« Reply #13 on: April 18, 2014, 11:49:24 AM »
Quote from: Sky;31727
I agree POP!!!! Add some red fenders and lets see what she looks like!!!!  I have to LED Puma pipe on my Puma. Works very well!
Duner project
« Reply #14 on: May 10, 2014, 01:29:59 AM »
I got my build pretty well done just some final touches and it's complete. Took it for a test run today and it flat out rips!:nevreness: Cant wait to get it on the sand!
