Author Topic: Ignition  (Read 51738 times)
Offline T8R6X
Ignition
« Reply #15 on: July 11, 2013, 11:33:04 PM »
I don't know much about this, but is that much advance good?
Ignition
« Reply #16 on: July 11, 2013, 11:35:45 PM »
here is a picture of the BDT flywheel compared to a 2001 CR250 flywheel, BDT's flywheel has a 200 gram weight added to it.
That would make the the bike feel closer to a stock style flywheel but probably still rev quicker since its much smaller diameter
BDT flywheel on the scale
Stock 2001 CR250
Ignition
« Reply #17 on: July 11, 2013, 11:38:35 PM »
Interesting, thanks for all the info you have added to the site.
Offline mx250r91
Ignition
« Reply #18 on: July 11, 2013, 11:43:40 PM »
Any idea on why the pulse trigger on that bottom flywheel is so long?
Ignition
« Reply #19 on: July 11, 2013, 11:53:45 PM »
The longer the pulse trigger the larger the spread on the ignition curve can be.
But the cdi can be programed with a shorter spread you just can not go longer than the amount of degrees that the triggers length in crank degrees
Seanoktm found when he switched from a trx250r flywheel to a cr250 flywheel his timing spread shortened 2-3 degrees with his MSD ign because of the shorter trigger length of the CR flywheel.
Ignition
« Reply #20 on: July 12, 2013, 12:27:00 AM »
The motor will have more inertia and less likely to stall but will rev slower but not slower than stock, small light flywheels are a love it or hate it kind of thing.
I think they did good by adding the weight myself but thats me.
Ignition
« Reply #21 on: July 12, 2013, 07:40:26 PM »
http://www.servicehonda.com/cr500-ignition-and-light-coil
Looks like the bdt kit might just be the same as the service honda set up. Flywheel weight and lengthy pick up.
I kinda wish i would have just went this way, now that the cr250 cdi is discountinued...
Offline mx250r91
Ignition
« Reply #22 on: July 12, 2013, 07:46:35 PM »
Quote from: sameltoe;3281
I noticed the same thing. I thought they designed and built their own ignition but it looks like they ripped off service honda's design.
Ignition
« Reply #23 on: July 12, 2013, 07:53:06 PM »
I am sure BDT will deny it, but even the coil wires are setup for a cr500 coil, Jim has to cut the female round plug off and install a female flat blade to go on the CR 250 coil.
No instructions came with it so I just downloaded the wiring diagram from service Honda and magicly they were the same.
It even has a extra coil output wire for a tach like service Honda shows.
It looks like a nice setup none the less and we are going to slot the stator to get the curve where we want it.
Ignition
« Reply #24 on: July 12, 2013, 08:01:31 PM »
But we need to modify the cr250 adaptor plate to work with the 500 stator plate correct?
Offline derby
Ignition
« Reply #25 on: July 12, 2013, 08:34:32 PM »
How much do you plan on advancing at the stator?
Ignition
« Reply #26 on: July 12, 2013, 08:38:10 PM »
We are thinking 4-5 degrees, sometime this weekend I will try to make up a graph showing the 4-5 degrees added at the stator plate.
Derby didn't you say yours started better with a little advance when starting it.
Ignition
« Reply #27 on: July 12, 2013, 08:46:41 PM »
Quote from: sameltoe;3288
No the stator plate works with the CR250 stator adapter you get from esr, or others that make them.
Offline 2strokesforever
Ignition
« Reply #28 on: July 12, 2013, 09:26:33 PM »
so i can get the ESR adapter plate and this kit http://www.servicehonda.com/cr500-ignition-and-light-coil and it will be a good performace upgrade like the other kits but I will now be able to run lights?
88 TRX250R
295cc L.A. Sleeve Big Bore Kit
Pro Circuit pipes, Pro Design head
Ohlins-Works Performance Suspension
IMS Pro Series controls
38mm Keihin Air Stryker Carb
200 watt Ricky Stator stator
Boyesen Rad Valve
KEEP THE DINOSAURS ALIVE!!
Offline derby
Ignition
« Reply #29 on: July 12, 2013, 09:34:37 PM »
Advancing my setup I thought the bike started up easier.  When I was using the programmable dyna fs, I found that if I put the startup timing at 0 degrees the bike was hard to crank.  It always seemed that around 7-8 degrees it became much easier.  Even with the 01 cr250 ignition advanced up to 6-8 degrees I never did have a problem with kickback.  I thought one of the older service honda cr500 ignitions from years ago used a modified cr125 stator and it did not have the groove in the back of the stator plate.  But it sounds like, and dave can confirm this, if they use a cr250 stator the groove should be cut in the back of the stator plate and it will bolt right up to the esr plate no mods needed like I referred to earlier in the post.
« Last Edit: July 12, 2013, 09:48:11 PM by derby »
