Author Topic: What hydraulic clutch to buy and where?  (Read 3291 times)
Offline hondaman77
« on: April 18, 2014, 12:17:42 AM »
I bought a magura on ebay and it didn't move the actuator arm enough to disengage the clutch so I gat annoyed and sold it. Where can I buy a hydraulic clutch that will be bolt on and go on the R?
« Reply #1 on: April 18, 2014, 02:37:41 AM »
Magura is the best you can buy. next up would be a Streamline. they can be hard to bleed and the early version of the Magura had seal problems. perhaps you had one from that batch. don't give up! if you can find a new Magura I would give it another shot. the quality of the streamline is not as good as the Magura.
a new OEM or motion pro terminator cable with a EZ pull clutch lever and perch will provide you a butter smooth pull too. cheaper in the end also.
Offline TRXforever
« Reply #2 on: April 18, 2014, 07:57:52 AM »
I put buna-m seals in my magura, and it has lasted three seasons so far, with just a re-bleed before first rip every year. My clutch is like butter. I will NEVER use any other clutch setup.
« Reply #4 on: April 18, 2014, 09:43:07 PM »
I run magura on my mx bike and my xc bike both. Its an amazing setup. Best ever. Many seasons on both. No issues since they updated the slave cylinder.
« Reply #5 on: April 18, 2014, 09:54:24 PM »
See josh is straight up
