Author Topic: Radiator hoses  (Read 2805 times)
Offline Nickthompson
Radiator hoses
« on: April 22, 2014, 06:14:44 PM »
Looking for a set of white or clear radiator hose
Offline Wes350x
Radiator hoses
« Reply #1 on: April 22, 2014, 06:21:12 PM »
The clear hoses I've seen used are the braided pvc hoses found at hardware stores. They seem to change color of whatever coolant you use. Not sure what's the long term life of them.  I did see some white/clear ones that a member here had on his drag puma but he said he had fitment or leaking issues.  I believe he bought them from RMATV.
1988 250R
Radiator hoses
« Reply #2 on: April 22, 2014, 09:09:14 PM »
cv4 makes white silicone hoses.
Radiator hoses
« Reply #3 on: April 24, 2014, 11:32:04 PM »
They only make red and blue for the R
Radiator hoses
« Reply #4 on: April 25, 2014, 12:01:34 AM »
Quote from: Wes350x;32129
Stay away from the braided PVC and vinyl clear hoses. The plastic will not take the heat. They do not hold up when the hot water under pressure flows through them.  We have replaced a lot of top ends that got nuked when the hoses failed
