Author Topic: Parts lot. Bunch of random stuff.  (Read 2250 times)
Offline 1bad88r
« on: April 28, 2014, 11:21:08 AM »
Gibson 6 clicker damper good shape $75
Heavy duty +2 tie rods $45
Pumashine gusset kit standard 88-89 $50
Flywheel stator harness 2 cdi and coil  harness has a wire or two cut $50
Carrier needs bearing. $45
Rear hub $10
2 pwk throttle cable and a clutch cable. One throttle cable is new $40
1 Ball joint 12mm moog es419r $15
2 ball joints 14mm moog es3045rl $30
Set of front pads $20
Random seals $15
New 13 tooth sprocket $10
Radiator brackets $5
Steering stem bushing $10
2 new a-arm bolts $5
 Water pump gaskets $5
Reed gaskets $5
Lug nuts $5
Clutch cable bracket $5
New Oil check bolt $1
Big orings are for a honda rancher air box. $5
water pump and cover $15
I'll sell everything for $350 shipped
I can't get picture to load to my photobucket
here is a link to my craiglist ad for now.
http://cincinnati.craigslist.org/sno/4444072897.html
Price include shipping within the states.
January 09 join date pre you know who.
Offline 1bad88r
« Reply #1 on: May 02, 2014, 07:09:12 PM »
Bump
