Author Topic: Radiator Recommendations  (Read 5635 times)
Offline 08IRS
« on: April 29, 2014, 09:38:11 AM »
I think my radiator is on its last leg so it is time for a replacement. I see the cheap ones from China on eBay for 65.00 or the PWR for about 390.00.
Any recommendations?
Offline Bigred
« Reply #1 on: April 29, 2014, 09:46:38 AM »
I have a good oem if u want oem one
1986 R
260cc oem cylinder
tc ported
38mm as carb
boyseen reeds
Ohlins front shocks
redone oem rear shock
93 pump fuel
cool head inline temp gauge
« Reply #2 on: April 29, 2014, 09:53:21 AM »
Quote from: 08IRS;32656
What size cylinder are you running?
Offline 08IRS
« Reply #3 on: April 29, 2014, 09:54:48 AM »
Stock at the moment, but I have a ESR310 that I will put on later this summer.
I also do a lot of woods riding on tight trails so we run at a slow pace for periods of time.
Offline 08IRS
« Reply #4 on: April 29, 2014, 10:00:05 AM »
Quote from: Bigred;32657
Thanks for the offer.  I will let you know.
Offline Bigred
« Reply #5 on: April 29, 2014, 10:13:18 AM »
Stock  would do fine just curious why u think yours is bad
1986 R
260cc oem cylinder
tc ported
38mm as carb
boyseen reeds
Ohlins front shocks
93 pump fuel
« Reply #6 on: April 29, 2014, 10:28:25 AM »
I would save up and go for a larger radiator if you are going up to a big bore. I know it's not much bigger but if you will be doing alot of 1st and 2nd gear riding through the woods on hot days, it might be worth having the larger cooler.
Offline 08IRS
« Reply #7 on: April 29, 2014, 10:55:32 AM »
Quote from: Bigred;32662
I noticed a few drops of coolant from the center of the radiator.
Offline 08IRS
« Reply #8 on: April 29, 2014, 10:57:15 AM »
Quote from: rablack21;32663
Any other brands I should look at?
« Reply #9 on: April 29, 2014, 10:59:31 AM »
I would consider PWR, Afco, and fluidyne. Fluidyne used to make Walsh's oversize radiators, not sure if they will still make them or not. Afco makes a nice dual pass radiator for about $370, but has the inlet and outlet tubes on the same side, so you can't run factory hoses. PWR makes a good radiator as well.
Offline patman13mia
« Reply #10 on: April 29, 2014, 01:10:39 PM »
I went from stock to the fluidyne rad. Really nice radiator. I went from oem cylinder to a 350cc though so i wanted to be safe with the extra heat. I also have a really nice stock rad with no bent fins and also a grill on the front. Will sell for cheap if ya want it
Offline zarathos
« Reply #11 on: April 29, 2014, 02:44:26 PM »
Check out these guys http://www.motorcycleradiators.com  All they do is repair and sell powersports radiators. I've heard good things about them.
Offline ryanowarrior
« Reply #12 on: April 29, 2014, 04:09:55 PM »
I have a Walsh style rad I might sell
Laeger Crf
Laeger R
Walsh R
Walsh Crf (in the works)
