Author Topic: sphynx questions.  (Read 4915 times)
Offline d-rock
sphynx questions.
« on: May 01, 2014, 07:35:39 PM »
On a CPI sphinx cylinder.
1- what do you use to seal the exhaust flange to the cylinder?
2- there are 2 holes at the base that go into the water jacket. They should take a pipe plug but what do you seal them with? The threads are poor, I don't think Teflon tape will seal it. I was thinking of epoxying them in.
Thanks. Derek.
Offline kb250r
sphynx questions.
« Reply #1 on: May 01, 2014, 07:47:52 PM »
I used hi temp silicone for my exhaust flange on my Puma and I'm sure the same would work for the water jacket plugs as well
Atc - 350 6mill
Atc - 350 4mill
Trx - 431 puma
Engineered by C-Leigh Racing
Offline GO OVRIT
sphynx questions.
« Reply #2 on: May 01, 2014, 07:54:20 PM »
If its that bad, can you clean them up with a tap?
Offline d-rock
sphynx questions.
« Reply #3 on: May 01, 2014, 08:20:19 PM »
Plugs thread in fine but on 1 side of the hole there are no threads. I think the holes are there from casting and were to big for the tap.
Offline kb250r
sphynx questions.
« Reply #4 on: May 01, 2014, 11:48:11 PM »
Is that a brand new cylinder?Did you recieve it like that...?
Atc - 350 6mill
Atc - 350 4mill
Trx - 431 puma
sphynx questions.
« Reply #5 on: May 02, 2014, 10:24:07 AM »
Got some pics?
sphynx questions.
« Reply #6 on: May 02, 2014, 10:35:08 AM »
after millennium acid dips and sand blasts them the threads sometimes look a little ragged but it should still seal fine unless someone has jacked them up. you can just use pipe sealant in liquid form, teflon tape or even a good silicone on the threads and you will be fine
Offline d-rock
sphynx questions.
« Reply #8 on: May 02, 2014, 12:03:31 PM »
Quote from: rsss396;32907
i think your right, they look sand blasted, ill try sealing them up and pressure test before i assemble it .
 I have high tack and liquid teflon.
Thanks for all the input.
Derek.
