Author Topic: Wanted Loaner pipes for dyno runs  (Read 15376 times)
Offline Mickkey82984
« on: May 02, 2014, 09:22:53 AM »
Hey guys,
I'm going to have Jerry Hall build me a inframe pipe for my dune ported 363 sphynx, were looking to find as many pipes as possible that guys say works good on the sphynx to see how the engine responds to different pipe dimensions. You can ship it straight to Jerry's shop in Phoenix,AZ. As long as it cool with Jerry all dyno info will be posted. I'll pay Shipping and can give you some extra for the help. Let me know if any of you guys can help me out.
Thanks,
Mike
Offline rsss396
« Reply #1 on: May 02, 2014, 10:26:33 AM »
If you are paying for shipping then I probably have a inframe FTZ drag pipe I can send, I will even let Jerry cut the end of the stinger off that necks down from 1-1/4 to 1-1/8 for the stock silencer. that way both stinger sizes can be compared
Offline Mr250sx
« Reply #2 on: May 02, 2014, 10:34:16 AM »
I may be able to help out with a shearer sphynx out of frame depending on when..
« Reply #3 on: May 07, 2014, 03:59:52 PM »
Quote from: rsss396;32904
That would be awesome, I can pay shipping no problem. It problably won't be for another month. Its so dry up here in Northern Arizona their going to shut the forest down real soon, so I'm trying to get as much riding done as possible now.
« Reply #4 on: May 07, 2014, 04:03:50 PM »
Quote from: Mr250sx;32906
That be awesome, I probably won't even get my bike down to Jerry until after Memorial Day so maybe in a month or so.  Let me know if that will work for you.
Offline rsss396
« Reply #5 on: May 07, 2014, 05:02:06 PM »
That probably will be bad timing for us and Mr250sx since our season is just winding up
Offline 250Racer
« Reply #6 on: May 07, 2014, 11:30:58 PM »
I have a FTZ HI-rev inframe pipe that i wont be using until winter.
Online Tbone07
« Reply #7 on: May 08, 2014, 08:31:29 AM »
I have a Sparks MX that you can borrow, it's all clapped out but will work for your needs. Although you might blow up the 363 with this small of a stinger and header diameter lol
« Reply #8 on: May 08, 2014, 12:22:37 PM »
I have got a couple old LRD pipes that came with the last 250R I bought.  They're standard stinger.  But if you'd like to run those, then just let me know.
Offline mho250r
« Reply #9 on: May 08, 2014, 07:35:13 PM »
I am in Phoenix and have an ESR TRX 11 CM and an LRD Team B you can borrow for the day if interested, although both are standard stinger size.
Offline aberegg05
« Reply #10 on: May 08, 2014, 09:06:10 PM »
I have a dyno port pipe if ur interested in trying. Standard stinger
Offline FerrinMotorsports
« Reply #11 on: May 08, 2014, 10:00:40 PM »
I have A TRX11...It's an out of frame pipe but should work for what you are wanting to do.....Let me know
« Reply #12 on: May 09, 2014, 01:37:27 AM »
Quote from: FerrinMotorsports;33539
The TRX5, TRX9, TRX11 will probably fry the piston if the sphynx is trying to make more than about 55 hp on my dyno unless they have the 1 1/4 18 gage stinger and silencer.
These big bore engines need the large stinger with the larger through hole in the silencer core.  Any of the 250 pipes with the 1 1/8 od 18 gage stingers and through holes in the silencer will also be two small and will also hurt a piston.
We need a selection of pipes that are big bore pipes or 250 pipes with big bore stingers and silencers.
Offline Wes350x
« Reply #13 on: May 09, 2014, 07:05:41 AM »
When I had Mat Shearer build me a 370 Sphynx a couple years back I was on the fence about what build I wanted.... Dune port on gas, or drag port on methanol. He said for the dune/gas motor I would be able to get away with a Trx-5 CM pipe, he actually complimented that pipe very well stating it's the best "off the shelf" pipe he's tested.  I ended up doing a drag build and went with a shearer OOF. Just thought that was interesting.
1988 250R
« Reply #14 on: May 09, 2014, 04:15:52 PM »
Quote from: Jerry Hall;33548
Not sure what your saying here...Maybe my ESR 350 cylinder does not qualify for Big Bore Status but I have run it and run it hard for over 4 years and never had any piston problems running the TRX11  straight from ESR....It might have something to do with my complete package as the cylinder and cases were both modified...Either that or I'm just lucky????
