Author Topic: ESR310 Cylinder  (Read 2955 times)
Offline 08IRS
ESR310 Cylinder
« on: May 05, 2014, 09:05:01 PM »
I have an ESR310 cylinder, dome (I believe pump gas) and head that I am thinking about selling.  I decided I may put the money towards my suspension upgrades instead of engine at this time.  It is still on the 72mm bore and has C7 engraved onto it below the exhaust port.  It needs a piston and water neck.   Can anyone give me an idea of what it is worth?
Offline dirtyd
ESR310 Cylinder
« Reply #1 on: May 05, 2014, 10:36:54 PM »
Consider a new 310 kit from ESR is $599. $699 with TRX7 porting. Yours needs a piston ($200 with gaskets) water neck ($25). Now yours might need to be honed or bored the next size. So I'm going to guess $150-200 range.
87 Tecate4- new project
Offline 08IRS
ESR310 Cylinder
« Reply #2 on: May 06, 2014, 10:32:19 AM »
It was honed before it was sent to me.  If its worth less than 200.00 I'll just put it on the shelf until I am ready to install it.
Thanks,
George
ESR310 Cylinder
« Reply #3 on: May 06, 2014, 10:43:11 AM »
Yeah i'd say $300 tops....but even then, i'd say keep it.
Offline 08IRS
ESR310 Cylinder
« Reply #4 on: May 06, 2014, 10:53:03 AM »
Just to verify, does C7 indicate TRX7 Porting or the Port Match 7?   I'm guess Port Match 7 as it is not as smooth as I would of thought it would be.
