Author Topic: 38 Air Stryker twist throttle cable?  (Read 2804 times)
Offline TRXforever
« on: May 11, 2014, 09:36:24 PM »
This has been covered a few times before, but I bought a 38mm air stryker and my old cable is clip on style and doesn't fit the adjuster on the top of the air stryker. Does anyone know a replacement that will fit? I need a new twist assembly also. I ran the CR style for ages thinking of a whiporwill. Any kit suggestions would be great!
Offline christph
« Reply #1 on: May 11, 2014, 10:52:49 PM »
Give Motion Pro a call.  They have a ton of pre-made cables and they also make custom cables if necessary, with a the right fittings, length, etc.  I had a couple custom cable made for 40 bucks or so.  In fact, they were for the 38 Air Stryker.
1982 ATC 250R
1984 ATC 250R
1986 ATC 250R
1988 TRX 250R
Offline mx250r91
« Reply #2 on: May 13, 2014, 08:45:18 PM »
I use a 2000 CR250 OEM twist throttle and cable. Works perfectly with the 38mm PWK A/S as this is the stock carb on this year CR (and 99 too). The cable is about $15 from Honda.
Offline TRXforever
« Reply #3 on: May 15, 2014, 10:15:40 AM »
That is the information I was looking for! THANK YOU mx250r91!
