Author Topic: big bore pipe comparable to trx5?  (Read 6169 times)
Offline GO OVRIT
« on: May 12, 2014, 02:13:26 PM »
I think it's time to switch to a big bore pipe.  I like the power of my esr pipe and want something with a comparable power band.  The engine is a midrange ported 344.  Also what is a good silencer with the larger core?
« Reply #1 on: May 12, 2014, 02:28:06 PM »
« Reply #2 on: May 12, 2014, 02:47:10 PM »
Get a trx5b. Same stinger and silencer but runs 10 degish cooler. You don't need a larger stinger with it.
Offline Bowtie316
« Reply #3 on: May 12, 2014, 03:42:46 PM »
Consider modifying your pipe for big bore. http://trx250r.org/threads/1662-Big-bore-stinger-project
« Reply #4 on: May 12, 2014, 04:27:38 PM »
Huh, just run the 5? I run one on a 363 and have no issues.
Offline GO OVRIT
« Reply #5 on: May 12, 2014, 08:36:56 PM »
Well it was suggested that the restrictions may be one of the causes of my recent piston failures.  I may be able to "get by" with different jetting,  or less aggressive riding, etc..., but I don't really want to slow down.lol  If it weren't a chrome pipe I might modify it, but I don't want a partially chromed pipe and don't know where to get it rechromed.  I've been thinking about that LED pipe, just want to see what options there are.
Offline Bowtie316
« Reply #6 on: May 12, 2014, 08:50:50 PM »
My modified pipe only burned the chrome off about 1/2" from the weld and it hasn't rusted.
Sent from my SGH-T679 using Tapatalk 2
Offline GO OVRIT
« Reply #7 on: May 12, 2014, 09:02:32 PM »
I checked out your link.  That turned out good.  What do you think after getting some seat time on it?
Offline Bowtie316
« Reply #8 on: May 12, 2014, 09:56:01 PM »
Pipe worked out fine, actually helped out on the low end and no heat issues to worry about. My problem was too much port timing.
