Author Topic: Elsinore Part out (Laeger/Saber)  (Read 10770 times)
Offline troybilt
« on: July 10, 2013, 10:05:29 PM »
All prices don't include shipping or paypal fees:
paypal:  crownlineboats@hotmail.com
1.  +4 Protrax front end, stem, spindles, aarms, tie rods - SOLD
2. PEP PB1's full compression rebound adjustable - PENDING
3. 1998 Laeger Narrow front, CR500 linkage rear XC frame, Fresh Chrome Subframe, Swingarm and PEP CR500, 8 Click Big Bottle Rear shock Fresh- SOLD
4. 496 Saber Motor, Hinson QC change, Fresh Piston, Arctic Cat Rod, V-Force 3, 155 psi compression dome, K&T drag ported - $3500 with QC cover, $3200 without...
More to come, starting here, not sure what all I want to keep yet!!
« Last Edit: July 11, 2013, 10:24:37 PM by troybilt »
Elsinore 496cc Saber
Offline troybilt
« Reply #1 on: July 10, 2013, 10:06:32 PM »
more pics
Offline troybilt
« Reply #2 on: July 10, 2013, 10:07:26 PM »
Frame
Offline troybilt
« Reply #3 on: July 10, 2013, 10:08:13 PM »
Offline troybilt
« Reply #4 on: July 10, 2013, 10:15:57 PM »
Quote from: spiritaces;2690
I'll take the frame
You serious?  as in frame, sub, swinger, rear shock, linkage?
« Reply #5 on: July 10, 2013, 10:19:55 PM »
O.o site owner gonna be ballin!
Offline JFMachado
« Reply #6 on: July 10, 2013, 10:46:07 PM »
How much for just the shock?
Interested in your arms as well, let me know.
Offline troybilt
« Reply #7 on: July 10, 2013, 10:50:48 PM »
front A-Arms are sold (Pending), rear shock will go with the frame/swinger.
Offline GO OVRIT
« Reply #8 on: July 11, 2013, 05:49:33 PM »
What makes it a xc frame?  Will it work just as well for mx?
Offline mx250r91
« Reply #9 on: July 11, 2013, 06:06:53 PM »
Interesting it uses a 86-87 style swingarm. I guess you could use that style rear engine mount just cut off the bottom tabs from it?
« Reply #10 on: July 11, 2013, 06:41:47 PM »
Laegers did not use the rear 88-89 style mount,nor does it use the 86-87 mount that bolts to the engine,it does use the lower 88-89 mount. Theoretically you could use both style swingarms which is why there is a center support tube with that swingarm.
Offline trx250-86
« Reply #11 on: July 11, 2013, 06:55:34 PM »
you selling your front  shocks?
Offline troybilt
« Reply #12 on: July 11, 2013, 10:23:49 PM »
I bought the swingarm so I could potentially use an 86/87 style mount cause the cr500 linkage doesn't use the upper rear motor mount.  Couple that with a Saber engine doesn't have a head stay I thought I was going to run into problems.   However, I never ran it long enough to find out. So is had a machined spacer to span across the opening of the swingarm pivot.  Works great with 2 grease zerks.
Note chassis is sold and shocks.
« Reply #13 on: July 12, 2013, 10:32:49 AM »
Did you decide on the brake lever?
Offline Sky
« Reply #14 on: July 12, 2013, 10:42:40 AM »
I wanna cry Troy... What a shame.. Good Luck and looking forward to your next build being just as creative and inspirational.
