Author Topic: pumashine's ftz cylinder  (Read 26776 times)
Offline patman13mia
« Reply #75 on: June 07, 2014, 04:33:39 PM »
also by the sounds of it my cylinder should be here before the dune trip. neil said it just needs bored and then im ready to ride!! man i cant wait!! ready to see what the difference in power is from stock to 350
« Reply #76 on: June 07, 2014, 04:58:46 PM »
Quote from: patman13mia;35953
LOL, You will be wondering why you did not do it 10 years ago. The bottom end torque is amazing.
Offline patman13mia
« Reply #77 on: June 07, 2014, 06:00:46 PM »
hell yea!! ill just keep moving up in dispacement as i go!! get some big boys like you got
Offline patman13mia
« Reply #78 on: June 19, 2014, 04:43:06 PM »
check out the base gasket... i would say this wont hold a seal lol.
« Reply #79 on: June 19, 2014, 05:48:54 PM »
Quote from: patman13mia;37125
Better put some sealer on there this time.
« Reply #80 on: June 19, 2014, 10:21:13 PM »
pat i hope you dont mind some constructive critisizem. them wiseco cranks and rods have a high failure rate. a piston with the forward facing side cutouts often times create a undesirable shortcut from the exh to crankcase. even with just a rearward facing cutout i still dont think its a good thing because it leaves a large gap between piston and cylinder wall at bdc. a full circle piston would be best but alot of times they dont make that style for a particular engine so were are forced to use alternatives with less than ideal designs
Offline patman13mia
« Reply #81 on: June 19, 2014, 11:09:38 PM »
what piston fo you use when you build your 250r's??
« Reply #82 on: June 20, 2014, 01:12:06 AM »
i would be more concearned about that rod. if the crank is a wiseco i would have concearns about that also. when they break its a train wreck. i hope your one of the few that dont have problems
im not familiar with all the different 250r styles of pistons so i cant answer your question directly. maybe someone else around here can ?  to me that looks like a old version of a wiseco. why they ever designed them like that is a mystery to me.  years ago the cr500 piston looked the same and probly many other pistons. a light bulb must of went off and they realized the errors and corrected it partially with the cutout only on the back half. still i think its best to not have any side cutouts but often times you dont have a choice depending on what engine your dealing with.
these arent necesarrily for your engine but i think something like one of these designs would be a better choice if you have the option.
[ATTACH=CONFIG]5462[/ATTACH]
[ATTACH=CONFIG]5463[/ATTACH]
[ATTACH=CONFIG]5464[/ATTACH]
