Author Topic: 38mm air Striker carb from ESR  (Read 5735 times)
Offline 08IRS
« on: May 23, 2014, 06:21:41 PM »
Question.  If the carb is machined on the airbox side should it slide into the airbox boot without issue?  It close but I am afraid of tearing the boot.
Offline muthahucker
« Reply #1 on: May 23, 2014, 09:10:15 PM »
I just got one a few weeks ago as well from ESR withthe machined ends.  Its a very tight fit but if you warm up your airbox boot in hot water for a while before installing, it should slide right on
« Reply #2 on: May 23, 2014, 10:10:13 PM »
It is a tight fit, but as mentioned, warming it up will improve the insertion! :shame:
« Reply #3 on: May 23, 2014, 10:16:26 PM »
Quote from: F-Red;34701
Haha typical Friday night comment from this guy! Now where's the pics!?!?!?
Offline mx250r91
« Reply #4 on: May 23, 2014, 10:37:27 PM »
Hard to beat Partzilla on price too, $174!!! http://www.partzilla.com/parts/detail/honda/HP-16100-KZ3-J21.html
Offline aztecgwynn
esr air stryker
« Reply #5 on: May 23, 2014, 11:40:21 PM »
Bought this air stryker with machined intakes on it. It is still a bit tight but leave plastic boos in sunlight for a few hours while sun is bright or hot outside. Then slide intakes on air box boot and rubber reed boot and let cool down for a bit.
Offline 08IRS
« Reply #6 on: May 25, 2014, 09:58:51 PM »
Quote from: muthahucker;34685
Hot water worked great.
Offline wilkin250r
« Reply #7 on: May 26, 2014, 04:26:51 PM »
I like to use hot water as well.  I've known a couple guys that used heat guns without knowing what they were doing, and melted their boot.  Impossible to melt it with hot water.
