Author Topic: jetting help  (Read 9466 times)
jetting help
« Reply #15 on: June 04, 2014, 12:26:33 AM »
Is the engine using transmission oil?
Turn out the air screw and see if it idles any better.
 If the idle speed picks up when your turn out the air screw turn the choke knob clockwise to slow down the idle speed.
« Last Edit: June 04, 2014, 10:28:01 AM by Jerry Hall »
Offline Bowtie316
jetting help
« Reply #16 on: June 04, 2014, 08:15:27 AM »
Have you checked the condition of the reeds?
Offline Dreamer
jetting help
« Reply #17 on: June 04, 2014, 09:39:31 AM »
I haven't pulled the reeds out yet and i don't know if it is using trans oil. It did great in the leak down test which makes me beleive it isnt. The air screw had little affect on the idle, same with the idle screw although it did change more than it did when there were two o rings in it.
jetting help
« Reply #18 on: June 04, 2014, 02:52:11 PM »
If it starts to run correctly after you shut the fuel off and that is repeatable,you are dumping extra fuel from some were.just because the float is set correctly doesn't mean that it sealing up completely I always check this by hooking the gas line up with bowl off and lightly lifting float to see if it shuts off completely debri can keep it from sealing or just worn out.once you get it to stop dumping extra fuel make sure to correct jetting
Offline Dreamer
jetting help
« Reply #19 on: June 06, 2014, 07:11:29 AM »
Pulled the float bowl off and manually pushed the float up with the fuel petcock on, no fuel cam out with even the slightest pressure applied so i know that isn't the issue. Put the new B8EG plug in gaped at .020 and same thing, no change in idle or throttle response. I pulled the reeds off to make sure they were in good shape and they looked perfect so cross that off the list. The intake port and reeds were soaked in fuel though. I've ruled out transmission fluid, the level has not changed at all and the fluid still looks clean as can be. I'm running out of ideas on what to check without completely replacing the carb.
jetting help
« Reply #20 on: June 06, 2014, 07:47:53 AM »
Dreamer check to see if the motor has filled up with fuel. If so with help you can dump it out by pulling the pipe and tipping the bike on its head. If it is full of fuel be ready with an extra spark plug if it fouls clearing it out.
Offline The_Steve_Man
jetting help
« Reply #21 on: June 06, 2014, 09:58:13 AM »
I have a 38 pwk that I would let go of.  Pulling it off my bike to put a 39 back on.  Works perfect.  I just like the 39 on mine better.
Offline patman13mia
jetting help
« Reply #22 on: June 06, 2014, 10:34:42 AM »
i have a 36 pwk that i scraped parts off of. if you pay shipping you can have it. i can send it out today if you really need it!! it doesnt need but a couple little parts that you can use from your carb you have there. they will switch right over. just let me know whats up
Offline Dreamer
jetting help
« Reply #23 on: July 01, 2014, 10:18:42 PM »
Finally got it running today with the 38 mm pwk from the_steve_man.  Running a 165  main and a 55 pilot. Bottom end is pretty rich and top could go maybe 2 or 3 jet sizes down but that can all be worked out with some time. Thanks for the help guys.
jetting help
« Reply #24 on: July 01, 2014, 10:35:23 PM »
Glad you got it running.
