Author Topic: The ultimate 2 stroke pipe  (Read 15921 times)
« on: July 10, 2013, 11:29:31 PM »
This pipe has a servo motor to adjust the tuned length of the pipe to match the rpms of the motor.
Longer pipe for low RPM's and shorter for high RPM's
http://www.youtube.com/watch?v=mvV4xbFKs0g&feature=relmfu
« Reply #1 on: July 10, 2013, 11:42:58 PM »
That is cool. On the R maybe a trombone layout would work. Piston rings for sealing? Periodic cycling to keep the joints clean?
« Reply #2 on: July 11, 2013, 09:33:00 AM »
I forget the details how they sealed it put I know it took a few differant designs to get one that worked that sealed without binding up.
Not much room on a trx for the typical style pipe to have a adjustable header but maybe something that had less movement could be done
« Reply #3 on: July 11, 2013, 09:46:05 AM »
i theorized about a reed style pipe tuning that would have a similar result.
« Reply #4 on: July 11, 2013, 11:02:58 AM »
will postup some pics of your ideas :)
« Reply #5 on: July 11, 2013, 11:09:28 AM »
My dad used to run Karts, he ran a dual KT100 class. The pipes on it were a slipper design. Had a cable that came up to the steering wheel that you could pull on in the upper RPM range. The slipper portion was internal unlike the video. Pretty cool set-up.
« Reply #6 on: July 11, 2013, 11:09:31 AM »
Quote from: rsss396;2817
the ideas havent made it that far.  its all in my head.lol
Offline troybilt
« Reply #7 on: July 11, 2013, 11:22:25 AM »
That's why I wanted to reverse the cylinder to run the exhaust straight out the back.  Had a similar idea as this.  Even modeled it... LOL!
Elsinore 496cc Saber
« Reply #8 on: July 13, 2013, 02:21:35 AM »
How much change in length would it take to broaden the rpm range by 2000? For example what difference in length between a trx5 and trx7?
Offline 363 stroker
« Reply #9 on: July 13, 2013, 02:27:28 AM »
Quote from: Rupp250;2821
I drove a kneel down hydroplane boat like that.  You would pull a lever on the straightaways and let go in the corners.
made a big difference in RPM. whole key was to remember when to pull and let go of lever.
LSR 363 R
Laeger 250 R
« Reply #10 on: July 13, 2013, 02:26:15 PM »
Quote from: rk88r;3366
about 300mm or around 11 3/4" for around a 2000rpm change
Offline DOUGLAS
« Reply #11 on: July 13, 2013, 06:07:25 PM »
Thats an awesome design. just need some one to build it.  i watched it over and over again it was starting to remind me of and old girl friend ha ha ha ha ha ha ha  [should of kept her]
LED 363 87 stock frame
« Reply #12 on: August 09, 2013, 03:22:05 PM »
more adjustable exhaust header ideas
« Reply #13 on: February 07, 2014, 04:33:10 PM »
https://www.bukupower.com/Pipes.aspx
the cone inside this pushes back (lengthening the exhaust) as the exhaust pressure rises just like how a powervalve opens.
« Reply #14 on: February 07, 2014, 04:45:42 PM »
Quote from: JesseA420;25052
this is very cool.
