Author Topic: Fabrication request  (Read 17818 times)
Offline atvmxr
Fabrication request
« on: May 31, 2014, 08:30:40 PM »
[MENTION=9]Pumashine[/MENTION]
Think you can make something like this?  It the oem 86-87 steering stem handlebar/headlight mount, cut up to fit over an aftermarket stem and provide way to mount headlight.
Credit to gooch on the other site
:positive:
Fabrication request
« Reply #1 on: May 31, 2014, 08:36:26 PM »
Quote from: atvmxr;35460
Anything can be made but this one I cannot make cost effective. If someone created this part then it is best to go to that guy to get it made.
Offline bnau267
Fabrication request
« Reply #2 on: May 31, 2014, 10:32:27 PM »
Quote from: Pumashine;35462
But just maybe you'll think up a new more cost friendly design!
Offline Rupp250
Fabrication request
« Reply #3 on: June 01, 2014, 09:41:11 AM »
Most people don't want to pay for R&D for there one off project. Or they don't realize hourly shop rates are not the same across this vast country.
My local fab shops around here have a $125 per hour rate and a $150 minimum. Unless someone see that they can make several of one item, and spread the costs out, a one off gets pricey.
DUNER -86 250R  Flinstone
@Kasey
« Reply #4 on: December 28, 2014, 04:27:45 PM »
Heres the new 3/4" thick triple tree   [MENTION=145]KASEY[/MENTION]  wanted made up for his next build.
Offline KASEY
Fabrication request
« Reply #5 on: December 29, 2014, 08:58:39 AM »
YES YES YES!!!!!!    pm me the details,,,  and I want a plain el cheapo motor stand ,,  I am going to paint it  to match my new paper weight !
Fabrication request
« Reply #6 on: December 29, 2014, 10:25:56 AM »
Quote from: KASEY;48156
As per your request I am cutting TRX250r motor stands without the Honda logo for cheap$$$. Aluminum and steel.
Offline KASEY
Fabrication request
« Reply #7 on: December 29, 2014, 01:38:21 PM »
Let me know how much and i will get it done....   WOOOOOO HOOOO  ready for the clamps ...
Fabrication request
« Reply #8 on: December 29, 2014, 02:07:59 PM »
me likey that pinch design ;)
Fabrication request
« Reply #9 on: April 25, 2015, 08:54:33 PM »
Kasey has alot of ideas for make trick parts for building ??? The small hubs have a 3 on 100mm BHC. He sent me the first pic but it is hard to duplicate because it is not to scale. I sent  croat1 the pic+info  and he sent me a file to cut the small hub. I modified his original file to what is now cut. Thanks Joe.
Fabrication request
« Reply #10 on: April 25, 2015, 09:15:41 PM »
looks sweet, i would have drawn the width of the center circle the same width as the width of the legs, the legs look a bit wider than the center circle but im sure they will work fine.
Fabrication request
« Reply #11 on: April 25, 2015, 09:43:27 PM »
Quote from: JesseA420;53703
Anything can be drawn. If it is not to scale then the physical limitations cannot be addressed.
Offline KASEY
Fabrication request
« Reply #12 on: April 25, 2015, 11:12:54 PM »
those are for ME!!!!!!   OHHH MAN,,  as of now i am with wood!!  here is what i do...
Offline KASEY
Fabrication request
« Reply #13 on: April 25, 2015, 11:24:19 PM »
i am real excited to challenge tony, so far he has done a fantastic job on all the goodies ... true craftsman ,,,, i made some hubs out of stock hubs and then went a step higher ,, results as seen ,, wagon hubs  ,, that's right wagon,,,,
Offline KASEY
Fabrication request
« Reply #14 on: April 25, 2015, 11:31:42 PM »
we talked about that,, but i it wouldn't have looked as EXTREME and that's what i wanted,, they look perfect...  bringing the imaginary second circle in helped make that happen ,, the fingers would not be as KOOOOL  if you did it that way,,,,
