Workshop
What reeds do I have?? Steel?
Topic: What reeds do I have?? Steel? (Read 4447 times)
supernutt
Total likes: 2
June 06, 2014, 08:12:08 PM »
Pulled these out of an 85 motor. Never seen steel reed pedals before. Should I use these or get different ones? Kind of a stock budget rebuild. Thanks
97 Laeger XC narrow CR500 link +4 t-pin
havinnoj
Administrator
Total likes: 185
June 06, 2014, 08:45:22 PM »
You have OEM reeds. I don't know what type of riding you do or budget but the first performance mods I always did on a stock engine were - pipe, reeds, head, and carb.
supernutt
Total likes: 2
June 06, 2014, 08:47:06 PM »
Ok. Thank you. Are they ok to use? They look ok
Pumashine
Supporting Member
Total likes: 27
June 06, 2014, 09:23:13 PM »
Quote from: supernutt;35918
If you are not looking for any performance gains they will work like any OEM trx250r parts....goooooood
Puma 408,
Puma 431,
Pilot 412,
Puma 431,
Mini-tooth 486
Trx450r
supernutt
Total likes: 2
June 06, 2014, 11:00:17 PM »
One of my co workers picked up an 86 trx with an 85 atc motor in it. Just going through a few things. Trying to convert him from his DS450 onto a simpler and better riding quad. He just wants the motor to be reliable and rideable for now. Might make performance mods in the future but for now it rolls as he bought it.
fearlessfred
June 07, 2014, 03:24:04 PM »
There is one good reason not to use them and that is when they break,they can do damage to the motor .Back in the 80s I had the whole reed break off and go through the motor,it damaged the jug close to the exhaust port and did not have much effect on performance
supernutt
Total likes: 2
June 07, 2014, 07:21:49 PM »
that thought did cross my mind. He will probably put v force or a rad valve in it down the road.
Bigred
June 07, 2014, 10:15:04 PM »
I got a stock cage with Boysen 3 flap reeds I'd let go for 25 shipped they will wake it up and there cheap ready to go
1986 R
260cc oem cylinder
tc ported
38mm as carb
boyseen reeds
Ohlins front shocks
redone oem rear shock
93 pump fuel
cool head inline temp gauge
supernutt
Total likes: 2
June 07, 2014, 10:16:20 PM »
I will let him know
Bigred
Reply #9 on:
June 07, 2014, 10:17:06 PM »
Ones on the right
1986 R
260cc oem cylinder
tc ported
38mm as carb
boyseen reeds
Ohlins front shocks
93 pump fuel
Workshop
