Author Topic: Advice on "broken " pro peg mount  (Read 2186 times)
Offline atvmxr
« on: June 08, 2014, 09:54:32 AM »
Lsr Baja frame.  The rear propeg mount is cracked all the way around.  Not the tube itself, but the connection point where the tube slides into the frame.  Is this a big deal?  With the nerf bars on, the tube can't slide out, so this seems like a superficial weld?
Thoughts?
« Reply #1 on: June 08, 2014, 03:08:38 PM »
if I'm thinking correctly a pro peg frame has the tube welded to the frame...and then the nerf slides onto the tube.  I say it needs welded.
