Author Topic: For Sale - PC2000 motor, Roll pegs + more  (Read 6237 times)
« on: June 09, 2014, 01:47:31 PM »
Duncan PC2000 275 motor - less than 5 hours on completely rebuilt engine top to bottom. Compression set at 185#, runs very, very strong.
New nikasil, crank, top-end, all bearings, seals, and bushings replaced. PC'd black side covers. Only typical case damage. Don't want to sell but I need a house
$1,200 shipped
88-89 Roll Pegs
- 100% mint 10/10 condition
$225 shipped
LSR +2 ST A-Arms
- Very good condition, no dents or dings, chrome is flaking a bit on upper right but not major. I ran these with 400EX spindles
$250 shipped
more to add later....
« Last Edit: June 09, 2014, 09:09:29 PM by Tbone07 »
Offline Kevhes11
« Reply #1 on: June 09, 2014, 02:21:06 PM »
What's the bore and stroke on the motor
« Reply #2 on: June 09, 2014, 02:24:32 PM »
Daaaaaang
Offline TRXforever
« Reply #3 on: June 09, 2014, 03:08:53 PM »
Double Daaaaaang!
Offline SARON81
« Reply #4 on: June 09, 2014, 03:21:15 PM »
Interested in selling the top end only?
« Reply #5 on: June 09, 2014, 03:41:02 PM »
Pegs and a-arms sold pending payment.
Not interested in separating motor.
Thanks
Offline Kevhes11
« Reply #6 on: June 09, 2014, 05:17:59 PM »
Bore and stroke...
Offline Vroomy
« Reply #7 on: June 09, 2014, 06:25:29 PM »
What size is the motor?
« Reply #8 on: June 09, 2014, 09:09:53 PM »
Quote from: Vroomy;36145
Whoops.....updated....275
Offline trx250scar
« Reply #9 on: June 09, 2014, 09:10:11 PM »
X3 What size engine bore and stroke. Also interested
« Reply #10 on: June 09, 2014, 09:11:13 PM »
Quote from: Kevhes11;36138
Bore and stroke...
69.5mm bore x 72mm stroke
Offline supernutt
« Reply #11 on: June 09, 2014, 10:09:53 PM »
What type of porting does the engine have?  I thought they had a eliminator and a high rev and something else......but maybe that doesnt apply to the aftermarket cylinders..
Offline mandom250r
« Reply #12 on: June 09, 2014, 10:16:38 PM »
Quote from: supernutt;36175
yea eliminator, national and hyperdyne. the hyperdyne is one of the first set-ups duncan did. it should be etched on the side of the cylinder. im thinking its a hyperdyne because this is an early model cylinder (check out the low rear base stud). there should be a number under the reeds part of the cylinder and if you give that to duncan they tell you every detail about that cylinder.
« Reply #13 on: June 10, 2014, 09:46:30 AM »
Engraved under the intake is "midrange"
Offline Rockingkfarms
« Reply #14 on: June 10, 2014, 11:06:40 AM »
Sent you a text last night tbone
