Author Topic: Saber top end on a pilot motor?  (Read 3666 times)
Offline troybilt
« on: June 10, 2014, 09:21:31 PM »
I've seen the pilot cylinders on a 250r bottom end, what about a Saber on a Pilot bottom end?  Just picked up my second pilot this evening, this one is going to be mine... mostly...  hehe....
Elsinore 496cc Saber
Offline troybilt
« Reply #1 on: June 10, 2014, 09:22:26 PM »
I've also see the rotax kits out there, 540's, 670's, etc...  I am considering it, but would rather keep the Honda "guts"...
Offline traxman
« Reply #2 on: June 10, 2014, 09:48:19 PM »
Do a liger..I'd think the bolt pattern would be closer (total guess) and you'll get more displacement. I believe the cr500 and fl400 strokes are both 79mm so the liger would be cast close for the stock stroke.
Offline troybilt
« Reply #3 on: June 10, 2014, 09:52:27 PM »
Quote from: traxman;36276
Ah.. I forgot about the liger... where's rsss when you need him.  I've seen several with CR500 cylinders on them, might be onto something there.
« Reply #4 on: June 10, 2014, 10:49:06 PM »
« Reply #5 on: June 11, 2014, 01:04:43 AM »
Quote from: troybilt;36272
Troy, the pilot can be bored to 85mm like a Puma. But that is the last bore. If you stroke it to a 4mil crank you will end up with a 431. But it seems you may want to look at a Liger. Good luck with whatever you choose to pursue.
« Reply #6 on: June 11, 2014, 09:03:08 AM »
I am sure a good amount of welding would still need to be done with a liger, troy send me your email again I lost your contact info with my new phone, I have some files that maybe would help
Offline troybilt
« Reply #7 on: June 11, 2014, 09:22:21 AM »
I'll shoot you an email
