Author Topic: She's all dynod in right  (Read 2933 times)
Offline Bigred
« on: June 15, 2014, 12:02:39 PM »
Went to Dyno again last night after I got some issues worked out
  176 psi.
Boysen rad valve
 fmf fatty power core 2 silencer
260 bore
93 pump fuel mixed 40:1
38 mm as carb
Stock cdi and electrics
Reed spacer for fitting issues
Full airbox w lid and snorkel
Last run
new run. Photobuckets being guy won't load it so hears my fb post https://m.facebook.com/photo.php?fbid=627597693996440&id=100002386444659&set=gm.10154237755715261&source=48&refid=18&_ft_&__tn__=E
1986 R
260cc oem cylinder
tc ported
38mm as carb
boyseen reeds
Ohlins front shocks
redone oem rear shock
93 pump fuel
cool head inline temp gauge
« Reply #1 on: June 15, 2014, 08:17:26 PM »
Nice job! That has a good broad power spread
did you try any changes on the Dyno?
Offline Bigred
« Reply #2 on: June 15, 2014, 10:27:42 PM »
Ya we did  we got more power but it was getting peaky. The way we have it now it has the smoothest curve and most usable power. It plant most the power to the ground to:)  I wish it had more tho lol. But it's a lot nicer than stock ha ha ha. 13/38 gearing big 21" Graber tires it pulls the front end 1st 2nd and 3rd if I want it to with very little effort
1986 R
260cc oem cylinder
tc ported
38mm as carb
boyseen reeds
Ohlins front shocks
93 pump fuel
