Author Topic: whats one of the best tools in your shop?  (Read 11147 times)
« on: June 15, 2014, 08:33:39 PM »
I'd have to say one of the best purchases I've made is an ultrasonic jewelry cleaner from Harbor Freight.
 I can stick parts in the cleaner and go do other stuff to get work done instead of cleaning parts by hand.
I clean a LOT of carbs and it is a serious time saver. I just pull the float bowl and cycle it a few times. Carb is done vs spending a half hour each carb pulling all the jets cleaning all the varnish and running a cleaner thru all the holes in the jets.
Let's me make money other places and I still charge the same for cleaning carbs.
Offline ytman
« Reply #1 on: June 15, 2014, 08:56:31 PM »
did you get the big one or the small one? How about a pic with the carb in it? I wanna see. Does it foam up or anything?
« Reply #2 on: June 15, 2014, 09:17:22 PM »
I got the big one. It's still not that big, carbs have to be flipped over to completely get cleaned.
I run mine with mineral spirits in it, seems to work best of stuff I've tried.
No foam or anything but it does make an pretty annoying buzz.
I know people freak about rubber and mineral spirits and or parts cleaner but if it's not left for an extended period of time it doesn't hurt.
I've probably cleaned 200+ carbs with either one and never had an issue.
It also works pretty well on chains. Just remove the heavy crap before you put it in or it will take longer to clean.
If I remember I'll grab a pic...
« Reply #3 on: June 15, 2014, 09:57:08 PM »
An 80 gal air compressor. Love me some air tools!!!
Online Tbone07
« Reply #4 on: June 15, 2014, 10:46:14 PM »
By far my favorite tools are the Tusk crank puller and case splitter
Offline jamieg45
« Reply #5 on: June 15, 2014, 10:54:49 PM »
I'm not sure I have just one, my whole tool box because it si full of everything I need to work on vehicles and especially my quads.
01 Lsr 250r
00 Walsh 250r
Offline GO OVRIT
« Reply #6 on: June 15, 2014, 10:55:17 PM »
Probably my blast cabinet.  There's a 350x frame in there right now.  My 80gal compressor is 170 feet from my garage in its own little shed.  Sure is nice having plenty of air without any noise.  I did just get a new scanner and lab scope, but that doesn't really help the r out any.
Offline Bigred
« Reply #7 on: June 15, 2014, 11:06:07 PM »
Kegerator. Saved a lot of shit from being broken again lol
1986 R
260cc oem cylinder
tc ported
38mm as carb
boyseen reeds
Ohlins front shocks
redone oem rear shock
93 pump fuel
cool head inline temp gauge
« Reply #8 on: June 16, 2014, 07:12:46 AM »
Quote from: GO OVRIT;36777
You must not have much freezing happening down there? Or did you dig the line down? I love that idea but it'd be tough in the negatives at times
Offline GO OVRIT
« Reply #9 on: June 16, 2014, 07:22:23 AM »
I've never had it freeze.  It's 1" pvc about 16" in the ground.  I try not to let moisture stay in the system anyway though.
« Reply #10 on: June 16, 2014, 08:52:01 AM »
Quote from: spiritaces;36810
I have simple man tools and nothing fancy lol, so my favorite is 12mm socket HAHA
A nice 6 point 12mm and 10mm used a hundred time a day.
Offline rsss396
« Reply #11 on: June 16, 2014, 09:13:09 AM »
I use the Tusk 8-10-12mm Y wrench allot along with a 8-10-12mm T wrench every time I work on my bike
But as fairly cheap must have tool I probably would go with a electric 4.5" hand grinder used with cut off wheels, flap sanding disc, scotch brite pad wheels and metal grinding wheels attachments makes it a very useful tool with any kind of fab work.
I really like my dewalt 5/8 arbor the best out of the 3 that I have
« Reply #12 on: June 16, 2014, 09:22:18 AM »
My Milwaukee 18volt Lithium impact driver with socket driver for 3/8" sockets. I use this bad boy almost every time I work on the R. Plus, this is really handy at the track when I need to do some quick work. I also recently required his big brother, M18V Fuel 1/2"  compact impact wrench. I can do virtually anything out at the track in quick time with minimal effort.
Offline rk88r
« Reply #13 on: June 16, 2014, 09:23:29 AM »
Yeh angle grinders get used a lot here. 3 of keep you from swapping wheels so often. The tool I use the most is dewalt cordless impact driver. Care must be taken not to over/under torque things though.
\'88 265 pv peps
One other \'88
« Reply #14 on: June 16, 2014, 01:56:43 PM »
One of my favorite tools that I picked up a couple yeas ago is a pneumatic micro die grinder. It's about the same size as a 3/8"X6" extension & works awesome for porting. I like my Miller 120V 140A mig welder a lot too.
