Author Topic: 88 xc 250r  (Read 11768 times)
Offline TLR-Online
88 xc 250r
« Reply #15 on: July 14, 2014, 06:07:25 PM »
Tested the Coil both ways = OK
Checked Stator/Pulse Gen = Ok
Kill switch, On/Off = Ok
Tried it with the kill switch unhooked. Tried it with key switch unhooked. Tried it with AC Reg unhooked. Tried it with AC/Kill/Light Unhooked.
Old plug was wet, tried new plug.
Whats left... CDI?
Offline ytman
88 xc 250r
« Reply #16 on: July 14, 2014, 06:15:20 PM »
Quote from: TLR-Online;38966
including plug cap?
Offline TLR-Online
88 xc 250r
« Reply #17 on: July 14, 2014, 06:17:17 PM »
Quote from: ytman;38967
including plug cap?
Yep, Actually it was a tiny bit high on both readings.
Offline TLR-Online
88 xc 250r
« Reply #18 on: July 14, 2014, 06:25:38 PM »
When i had it running, it did not idle... i had to keep my thumb on the throttle. If you let off it died.Didn't want to mess with it until after the idle break in.
Think it could be carb related? Stuck float? Broken Reed?
Offline DnB_Racing
88 xc 250r
« Reply #19 on: July 14, 2014, 07:05:26 PM »
Quote from: TLR-Online;38971
take the plug out and check for spark.. if it has a good spark ....then fuel related
