Author Topic: Which reeds and carb boot to get  (Read 3881 times)
Offline pantera1975
« on: June 24, 2014, 07:59:30 PM »
I need to get another set of v force reeds for a stock 86 ATC 250R what ones should I get? Got a part number. What Honda intake boot? Its got a stock carb but mite upgrade to a 38mm. Thanks
« Reply #1 on: June 25, 2014, 07:28:47 AM »
the vforce3's for our 250s are part number V305B. just get a stock carb boot.
Offline pantera1975
« Reply #2 on: June 26, 2014, 08:50:25 PM »
Thanks!!!
Offline Sand_Blaster
« Reply #3 on: June 29, 2014, 01:08:03 AM »
The new Vforce4's should be out real soon for the R's. Thee 4's work very well for the banshee's.
87 Trx250r & 99 Banshee
« Reply #4 on: June 29, 2014, 07:58:12 AM »
I just recently put on the 3's! Now 4's? What are the changes?
« Reply #5 on: June 29, 2014, 12:01:58 PM »
Quote from: Sand_Blaster;37843
Where did you hear this?
« Reply #6 on: June 29, 2014, 12:05:33 PM »
the boyessen rad valve is the best option.  less parts and more adjust ability with a radiator style hose.
« Reply #7 on: June 29, 2014, 12:42:39 PM »
Quote from: jcs003;37875
You must have a trick or way more patience than I do John!  Even using an ESR eliminator (radiator hose on the back of the carb bell), I have to finesse the placement of the Rad Valve-to-carb boot and air filter.  It's a real PITA to get all the angles right and tightened down.  V-Force (or other standard cage designs) with UPP intake manifold is much easier since the UPP allows the carb to move a bit while staying secure.
« Reply #8 on: June 29, 2014, 12:51:19 PM »
Quote from: havinnoj;37877
with the stock rubber from the rad valve its more difficult.  thats why i got a section of radiotor hose and i cut it the way i needed.  i.e. angle and length.  but, even then it was some maneuvering because the A/S carb is bigger than the PJ.  but i feel its the best way to go.
« Reply #9 on: June 29, 2014, 04:46:04 PM »
I'm just going by what I read here they should be available early this summer.
Offline Fear250r
« Reply #10 on: June 29, 2014, 10:57:40 PM »
Damn...I'm still running vf2's....
In house hybrid ball buster
