Author Topic: Build A Leak Down Tester!  (Read 3936 times)
« on: June 29, 2014, 09:42:19 AM »
Post up some pics of your leak down test, apparatus. Fairly simple to build PVC fittings.
« Reply #1 on: June 29, 2014, 09:51:23 AM »
thats fantASStic!..
Offline xTHUNDERCATx
« Reply #2 on: June 29, 2014, 10:50:58 AM »
what size is the pvc pipe for the intake boot? and how are you plugging the exhaust? I have seen 2, one was a freeze plug with a nut and bolt through it so when the nut tightened it created outward pressure then the other we had to improvise so we slapped a freeze plug in and used bailing wire to hold it in place lol.
« Reply #3 on: June 29, 2014, 11:35:17 AM »
PVC 1 1/4. O.D. Measures as shown. Chamfer the leading edge of the adapter. Slides right end! I use the rubber freeze plug, with the bolt, nut type. For the exhaust :eek-new:
« Reply #4 on: June 29, 2014, 11:42:18 AM »
Any chance you know what size freeze plug? I have to build a new set up sense mine is back home.
« Reply #5 on: June 29, 2014, 11:48:23 AM »
1 3/4 slips inside the ESR flange.
Offline GO OVRIT
« Reply #6 on: June 29, 2014, 03:42:55 PM »
This is one of mine.  It's a simple $13 blood pressure tester,  a small plastic T, and 2 rubber plugs.  The gauge goes to 320 mmHg which is about 6.2 psi.
Offline ytman
« Reply #7 on: June 29, 2014, 07:12:40 PM »
Those girls' butts are hanging out. just sayin'
