Author Topic: best oil to mix with race fuel?  (Read 16137 times)
Offline mwarman
« on: July 02, 2014, 05:19:45 PM »
Just wanted to see some opinions on what brand of oil everyone is mixing with their fuel. I'm currently building a ESR 350 and for many years I have ran motule 800t with very good luck. I've been running a 32:1 ratio with 110 octane. I've also been hearing good things about amsoil.
Offline patman13mia
« Reply #1 on: July 02, 2014, 05:31:33 PM »
i have a 350 also. i have always ran honda hpu and 110 race fuel.. have never had an issue and the smell is ohhhh sooo good!!!
« Reply #2 on: July 02, 2014, 05:49:56 PM »
Klotz Supertechniplate, runs in every 2 stroke I have, from pump gas to 110 to Alky
« Reply #3 on: July 02, 2014, 05:55:36 PM »
Non pv above 30 degrees run Maxima 927. Cold weather and power valve motors favor synthetic. I run Amsoil btw.
« Reply #4 on: July 02, 2014, 08:25:51 PM »
if this is a lame attempt of advertisement for amsoil i hope the mods shut this crap down .
« Reply #5 on: July 02, 2014, 09:19:15 PM »
Quote from: udontknowme;38254
The site does not care what oil you run. If it is a pyramid scheme I would close it out. I am running klotz r-50. Some good chit and real in expensive by the gallon 32:1
Offline PNWrider
« Reply #6 on: July 02, 2014, 10:42:23 PM »
X2 on klotz r50. Smells good too
40:1
« Reply #7 on: July 02, 2014, 11:14:18 PM »
the funny thing about amsoil is it seems popular with weekend dirt warriors that have fairly low power engines
i havent found anyone in other forms of highperformance 2t racing that will even touch the stuff
Offline atvcrazy
« Reply #8 on: July 02, 2014, 11:28:16 PM »
Maxima 927 for me 40:1 in 110 for me.  Will run this oil with non ethanol pump premium/a little race gas in the new ktm 250 I bought as well.  If you have ever torn an engine down with synthetic ran in it and the ones I have seen are dry as a bone no oil coating on any part I don't like that
« Reply #9 on: July 02, 2014, 11:29:47 PM »
Did the amsoil truck run over your dog lol. What do you use?
« Reply #10 on: July 02, 2014, 11:36:59 PM »
Quote from: rk88r;38269
What do you use?
not amsoil. lets just leave it at that  :glee:
« Reply #11 on: July 03, 2014, 07:24:17 AM »
Quote from: mwarman;38240
You will find that people have oil preferences like flavors of ice cream, there are a bunch of them. lol. Do a little research on different kinds of oil like the castor oil based Maxima 927 and then conventional oils, and then synthetics (Amsoil, Maxima, Klotz, etc.) Also look at the technical properties sheet or technical data sheet and compare. Look for ASTM testing. A reputable oil company won't hide its oil's properties. Then decide for youself what you should run. Several have listed a few good tips like, If you run in really cold weather or use a power valve, castor type oil is probably not for you.
Quote from: atvcrazy;38268
This is not normal to synthetics. There is a different issue going on there. If it was dry as a bone, there would have been seizure marks somewhere and/or browning of the parts that show overheating. I run synthetic oil and have torn mine down multiple times, and there was ALWAYS oil coating on everything.
« Reply #12 on: July 03, 2014, 09:21:21 AM »
110 octane, amsoil dominator 32:1.  it has worked great for me and my engine components look great.  probably got 100+ hours on my engine with no scuffing.
« Reply #13 on: July 03, 2014, 09:30:14 AM »
Can we get a smiley pisssing on another smiley? Just to represent a pissing match :)
Offline Bigred
« Reply #14 on: July 03, 2014, 09:36:28 AM »
I run the stuff from the gas station that has a jetski weed wacker quad and spmething else on the bottle lol never had a issue never fouled a plug. I think it more in the jetting than the oil personally any oil will lube the walls.  I'll catch grief I'm sure but it is what it is lol.  Only down side. Is it smells like he'll. But gives ya a cool blue looking fuel
1986 R
260cc oem cylinder
tc ported
38mm as carb
boyseen reeds
Ohlins front shocks
redone oem rear shock
93 pump fuel
cool head inline temp gauge
