Author Topic: Longer PWK throttle cable needed for ATC  (Read 3083 times)
Offline pantera1975
« on: July 06, 2014, 01:38:27 PM »
What throttle cable should I get for a  86 ATC 250R thumb throttle with a PWK carb that 4 inches or so longer than the stock ATC cable
Offline mx250r91
« Reply #1 on: July 06, 2014, 03:04:58 PM »
I'm using the motion pro TRX to PWK cable and it works perfectly on my 85, not sure how much longer than stock it is...
Offline pantera1975
« Reply #2 on: July 06, 2014, 07:19:00 PM »
I use ATV mid bend bars
Offline mx250r91
« Reply #3 on: July 06, 2014, 08:10:03 PM »
I'm using ATV high bend bars with precision shock and vibe mounts that puts the bar mount forward and higher than stock and the cable is plenty long enough.
Offline pantera1975
« Reply #4 on: July 07, 2014, 09:21:46 PM »
OK thanks for the info
