Author Topic: ESR Engine Cases  (Read 9665 times)
Offline madman636
ESR Engine Cases
« on: July 10, 2014, 11:38:40 AM »
Having no luck finding a good donor engine for my roller I have been looking at just getting a good set of cases and starting to collect bottom end parts.
Has anyone built an engine from the ESR Cases, 499 for a new set beats the hell out of 799 for a set of refurbished cases!
ESR Engine Cases
« Reply #1 on: July 10, 2014, 11:45:39 AM »
yes it is a hell of a good deal, i would scoop up a couple sets if i had any extra cash in a heartbeat!
ESR Engine Cases
« Reply #2 on: July 10, 2014, 12:10:45 PM »
They're on sale right now at that price - I wouldn't hesitate to buy them.  You can usually get used undamaged OEM center cases for around $400 too.
ESR Engine Cases
« Reply #3 on: July 10, 2014, 12:20:22 PM »
ESR cases are definitely worth the money.  those refurbished cases are WAY overpriced.
Offline KASEY
ESR Engine Cases
« Reply #4 on: July 11, 2014, 01:35:49 AM »
that $499 is totally bare cases too,,, so you will be over $600 pretty easy with bearings and seals,, plus the trans ,,,,  so figure $1000 to complete one ready to ride,,,
Offline madman636
ESR Engine Cases
« Reply #5 on: July 11, 2014, 09:52:42 AM »
Has anyone actually built a motor from them?  I have heard about a couple but never seen one.  I know they look nice and every time I see a set on ebay they want 400 for a beat up set with jb weld all over them!
Offline nico
ESR Engine Cases
« Reply #6 on: July 11, 2014, 10:08:36 AM »
I'm building one now... The cases (.210" extra deck height, machined for a 78mm sleeve) with bearings, and the online discount, were $590... Plus another $100 for misc. gaskets and crank seals, then I paid just over $200 for a nice low hour transmission, counterbalancer and clutch-side components from dill250R.  Add a $230 stroker crank from ebay and I feel like I have a fairly-solid foundation for my next dune engine.  The cases, bearings and included seals all seem really nice.
Offline Bio86
ESR Engine Cases
« Reply #7 on: July 11, 2014, 10:28:10 AM »
Just from looking at pictures, it seems like they beefed up some of the wall thicknesses and around some of the bearings.  That seem to be true seeing them in person?
McCoy\'d
Offline nico
ESR Engine Cases
« Reply #8 on: July 11, 2014, 11:23:54 AM »
Yes... I haven't measured them compared to a stock bare set, but there are numerous areas where the casting appears thicker.
ESR Engine Cases
« Reply #9 on: July 11, 2014, 12:03:57 PM »
There is also some added support bracing around the counter shaft, shift shaft and mount area.
Much stronger then the oem but some things can happen here that might take out anything that wasn't 30 lbs worth of added strength.
You can see it in the 4th photo.
http://www.eddie-sanders-racing.com/product_p/trx250r%20cases%20%201.htm
Offline Bio86
ESR Engine Cases
« Reply #10 on: July 11, 2014, 02:35:16 PM »
Oh yah if something nukes it's still going to push through it, curious how they hold up vs oem during a failure.  OEM look forged to me.
McCoy\'d
Offline D Bergstrom
ESR Engine Cases
« Reply #11 on: July 12, 2014, 05:43:54 PM »
Pretty good price. Don't need a set of cases, but thinking about buying a set "just because".
I know when these first came out there was a few issues with them. Guessing ESR has everything taken care of?
Doug
2004 TRX450R, 2008 TRX700XX
2008 TRX700XX
2005 TRX450R
1986 TRX250R
Offline nico
ESR Engine Cases
« Reply #12 on: July 13, 2014, 06:28:24 PM »
I had to clearance some for the +4 crank, with the .210" deck height set.  The counterbalances also appeared to just barely touch, but after I mocked it up, there is plenty of room.  Everything else has been really nice using these cases.
Offline Fear250r
ESR Engine Cases
« Reply #13 on: July 14, 2014, 12:26:48 AM »
Quote from: spiritaces;38884
I know someone who has a set and I seen them run in person so I know they work
My cousin, Rough250r has them and we rode this weekend.
In house hybrid ball buster
Offline rough250r
ESR Engine Cases
« Reply #14 on: July 14, 2014, 06:32:33 AM »
Yep the work I can confirm... The only issue is the counter balance area needs a little tune up because of a high spot on the inside of the counter balance cavity... But all is good all mating surfaces were flat so everything sealed well and all bearings seem to spin great that were installed at esr.. Hope that helps
