Author Topic: ESR Engine Cases  (Read 9707 times)
Offline rough250r
ESR Engine Cases
« Reply #15 on: July 14, 2014, 01:58:53 PM »
Yep I can confirm they work well... The only issue is the counter balance area needs a little tune up because of a high spot on the inside of the counter balance cavity on the stator side center case... But all is good all mating surfaces were flat so everything sealed well and all bearings seem to spin great that were installed at esr.. Hope that helps
« Last Edit: July 14, 2014, 08:10:35 PM by rough250r »
