Author Topic: Massive 250R parts lot sale - chassis stuff & goodies  (Read 2160 times)
Offline kt23
« on: July 20, 2014, 10:22:03 PM »
Massive 250R parts lot sale.
 *Houser +1+1 stem with 1.125" top clap with nice chrome $175
 *Aluminum airbox, perfect with no chain rub or cracks or scratches $90
 *RTC front brake lever and clutch perch/lever, nice, tight & straight $50
 *38mm Air Stryker car & cable $175
 *LRD unlimited rev CDI & wiring harness $100
 *Complete electrical setup, coil - CDI - mx cut harness - stator - flywheel $230
 *ProDesign kill switch, red with some fading, $15
 *ProArmour kill switch, fits both bar sizes, nice $25
 *86/87 seat with black/gray flame cover, nice $80
 *86/87 X Factor propeg nerf bars with all mounting hardware in perfect condition, will fit Laeger - Walsh - LSR propeg frames, just don use the hardware $150
 *X Factor propeg nerf bars for Walsh - Laeger - LSR propeg frames, fair condition $60
 *Cross flow oversize radiator $100
 *LSR steering block with bushing and bolts $35
 *ProDdesign -1 shifter $30
 *Nacs case savers, blue $10...
 *Hand made wire EDM cut case savers, new $10 each
 *(1) red air box ring $8
 *Wrap around billet exhaust joint seal $15
 *Chrome std length 86/87 brake pedal $25
 *Rath racing throttle cover $25 - just th cover or $50 for the whole throttle assembly
 *OMF radiator shrouds with the grommets & spacer mounts, very nice & perfect $45
 *AC belly pan with all mounting hardware $75
 *ESR red std length shifter $25
 *ESR -1 red brake pedal $30
 *ESR red water pump cover $30
 *Billet aluminum tapered lug nuts $25
 *Billet aluminum rear axle nuts $15
 *T&T black rear brake block off plate $10
 *86/87 billet gas cap $20
 *Poweremadd yellow/black handguards, with mounting hardware $20
 *Works Connection billet clutch perch, new cable, cable mount $50
 All prices are shipped in the US48 and include paypal fees.
 call text message for more details or pics
 270-402-2843
 Located in Lebanon, KY 40033
ktucker23@windstream.net
Offline supernutt
« Reply #1 on: July 20, 2014, 10:27:19 PM »
interested in the radiator......text sent
