Author Topic: Suggestions on swing arm chain protectors for 1986 trx  (Read 2631 times)
Offline Sky
« on: July 12, 2013, 09:16:18 AM »
Ok boys, SO i managed to suck the swingarm protector pad into the front sprocket, wedge it in between the chain- sprocket and case saver. Trashed the case saver and the chain but saved the case... Thanks to quadrider250r for helping out in the HOT heat and getting it back to the truck.
So Im in the market for a better protector. I need the lower frame as well as the swinger protector. Is there anything else out there someone can suggest better or not besides TM? I have Laeger +2 swing arm. I notice there is some that are solid and others that are like a open mouth that go around the pivot bolt and bolt on. Is this the difference between 86/87 & 88/89?  any help would be great.
