Author Topic: Got the new motor in  (Read 6278 times)
Offline Mickkey82984
« on: August 16, 2014, 09:12:18 PM »
I finally got enough energy to install my new motor. I got to modify my pipe mount, this saber scp pipe mounts in a different spot then my prox scp pipe did and still got to figure out where to mount the fuel pump.
« Reply #1 on: August 16, 2014, 11:49:19 PM »
Das a BIG cylinder
« Reply #2 on: August 17, 2014, 12:20:33 PM »
Quote from: Hawaiiysr;41063
Das a BIG cylinder
97mm, traxman said it one of the biggest sabers Pete ever built. I just hope this cinder beater frame can handle the hybrid power.
Offline udontknowme
« Reply #3 on: August 17, 2014, 01:08:45 PM »
not sure it matters much where the pump is located. i had concearns it needed to be below the fuel level but turns out that isnt true. had mine above fuel level and worked great. had the black mikuni. never tried any of the other ones
« Reply #4 on: August 17, 2014, 01:21:26 PM »
Quote from: udontknowme;41080
Thanks for the help. I think that's the pump Im going to run as well, Dave posted a pic of it on your alky tread a while back so that's the one I ordered. Can you post some pics of how u mounted yours. I'm a Rookie when it comes to big motors, fuel pumps and alky.
« Reply #5 on: August 17, 2014, 07:01:22 PM »
Very nice! Thanks for sharing
Best regards
-Jason
Offline udontknowme
« Reply #6 on: August 17, 2014, 09:01:00 PM »
im sure youll have many more options for a mounting location than i did.  back wall of the airbox is what i ended up doing and really i didnt have much other choice but it worked fine so i have no complaints . black pumps you can get from packard if need be. he also has tygon hose or you can get it from mcmaster. most my hose i got from mcmaster. seems like i was using 3/8 for the tank vent and the main line going from the pingle to the pump then 5/16 or somethin like that for the 2 lines out of the pump to the carb and 1/8 for powerjet lines
top view how i routed both lines into 1 then down to the carb. alot of what i did was trial and error as im sure youll find out also. the reason i have a extra piece of hose around the main hose is because the tygon doesnt seem to have good abrasion qaulities and i was having problems with vibration making the hose rub against stuff and it was sawing through the hose so i put a small piece of hose around the main hose in a few spots to protect it. the brass splice is simply so i can disconnect the pulse line there and remove the pump without having to pull the full length of line out, i can also disconect the fuel line at the Y so the pump can be removed rather easily. most likely you wont encounter any of these obstacles however
dilled out the stock gas cap and used a brass connector from the harware store. seems like it was 3/8 pipe thread on one end and a nipple on the other
Offline udontknowme
« Reply #7 on: August 17, 2014, 09:10:24 PM »
Offline atv fan 28
« Reply #8 on: August 17, 2014, 11:13:20 PM »
I didn't mount my pump to anything.  I used fuel injection hose for the lines and they're stiff enough to hold the pump up by itself. I might have a few pics if you need any.
Offline udontknowme
« Reply #9 on: August 17, 2014, 11:52:47 PM »
ya everyone has their own way of doing it. i dont think theres really any wrong way
Offline atv fan 28
« Reply #10 on: August 18, 2014, 12:17:22 AM »
I do remember being told to have your vaccum line pointed downward. The reason? I honestly can't remember.  But I believe Rss396 suggested I do it. Maybe he will chime in.
Offline udontknowme
« Reply #11 on: August 18, 2014, 12:36:13 AM »
im not sure but the only option i really had was to point it up. never had any trouble with it.  at first i had some concearn if the pulse line might be too long and the signal being weak but that wasnt a issue either. when you start the engine youll be able to see the fuel go through the lines and it gets to the carb instantly. thats how i knew i would be fine with the pump above the fuel and the long pulse line
Offline rsss396
« Reply #12 on: August 18, 2014, 06:58:39 AM »
The reason you want the pulse line and pump higher along with being pointed down is so oil does not build up overtime in the pump.
My snomoquad was like this for a few seasons and by the end of the season it would have a build up of oil in it until I mounted it higher than the vacuum port and it would naturally drain itself
« Reply #13 on: August 18, 2014, 07:05:08 AM »
Offline rsss396
« Reply #14 on: August 18, 2014, 10:56:55 AM »
yes a gusset kit would be a great upgrade, from the few saber stock frame setups I seen they had issues breaking the lower motor mount which is commonly broken anyways even on mild motors
