Author Topic: Flywheel wieght on CR 250 ignition  (Read 10019 times)
« Reply #15 on: October 15, 2014, 08:30:34 AM »
It was the most weight we could fit on the end of the flywheel. Total CR flywheel and weight is right at 800 grams total.  The CR flywheel by itself is less than 400 grams.  The OEM TRX flywheel is 1100 grams.
Now this is straight weight.  The CR flywheel is much smaller diameter, my flywheel weight is larger diameter which helps, but the TRX OEM is not only heavier, but much larger diameter giving it more rotational inertia.  I could run throught the calcs, but the point is that the Stock ignition still has a lot more.
« Reply #16 on: October 15, 2014, 08:44:42 AM »
Quote from: Burns363R;44582
Thanks for this info Kyle. I was gonna weigh these components myself for reference, but now I don't have to. With me having only added 283 grams with this 10 oz weight, it's probably not enough to quite see the difference that I am looking for. I might bump up to a 14oz-16oz and do some more testing. Sounds like you like the additional weight pretty well.
