Author Topic: 2000 Walsh 310R  (Read 5566 times)
Offline sangheraent
2000 Walsh 310R
« on: August 26, 2014, 12:31:04 PM »
2000 TRX250R Walsh Frame Honda 310R for sale. Bike has 12 hours on the  motor.
Motor:
All oem bolts used
brand new shift forks, trans bearings and gear shifting mechanisms
Brand new hinson clutch basket new clutch bearings 89 clutch
New primary drive collar and new counter balancer bearing
All new water pump brand new gaskets seals bearings
LA sleeve 72mm cylinder mx port
hot rods 4mm crank shaft
Vforce 2 reeds
cr250 ignition
39mm pwk carb also have 38mm air stryker
Suspension:
Full walsh MX narrow chassis (Frame, subframe, Stem, A-arms, Swing arm, rear linkage)
Brand new motowoz front shocks
front wave rotors with braided lines
Fasst flex bars with asv levers
GPR stabilizer
Rear PEP shock with rezi
CR500 rear linkage (have a spare)
Tusk +4 axle
Extras:
billet shifter
Billet kick starter
Billet brake lever
Curtis Sparks MX pipe raw fmf silencer
Fullbore Plastic
Walsh Quick release plastic mount (take all bike plastic off in less then 1 minute)
$6400
Offline GO OVRIT
2000 Walsh 310R
« Reply #1 on: August 26, 2014, 07:00:23 PM »
I like it.  I'm broke, but I still like it.  Good luck with the sale.  Where are you located?
Offline sangheraent
2000 Walsh 310R
« Reply #2 on: August 27, 2014, 12:40:21 AM »
Im in Abbotsford BC canada. Right on the border so I can ship fairly easily. Im not super pumped about selling it but have a ton of expenses right now. I really hope it doesn't sell though it is the best handling bike I have ever ridden. Now that its up for sale I wish I had spent more money on making it look pretty.
Offline Flyin_250r
2000 Walsh 310R
« Reply #3 on: August 27, 2014, 12:01:11 PM »
Damn, just what I need. A Walsh, and in Canada already lol. Now if only the bank account felt the same way lol
Offline kt23
2000 Walsh 310R
« Reply #4 on: September 05, 2014, 09:22:10 PM »
Still for sale?
